Old 08-25-2012, 07:26 AM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
Bambi II subfloor- 9/16"?
Hi-
All I ever read about on the floor threads is 3/4" plywood sub-floor (or 5/8" if people want it to fit a bit looser for an easier install), but I measure 9/16" plywood for the sub-floor on the Bambi II. Can anyone else confirm if this is what you found?
I am glad I checked and re-checked as I was about to order 3/4" marine grade plywood. That would have been an annoying mistake.
Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 08-25-2012, 08:57 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I have not heard of 3/4" ply in 60's era trailers. The number I usually hear is 5/8". It seems that the only way to know for sure is to measure your own every carefully, as the "standards" used at Airstream seem to have been pretty fast and loose, and varied between California and Ohio.
It seemed that I had 3/4" in my 70's era trailer, bought and installed the wood, and then found that it was slightly too thick for the C-channels to wrap around. Stranger still, I bought new C-channels, and these had an even smaller dimension than the originals. When I got it all installed and bolted down, the holes in the front plate on the frame matched up with the holes in the shell, which seems to verify that the original ply must have been pretty darned close to 3/4.
Good Luck.
