08-08-2017, 01:18 PM
1964 26' Overlander
Ingleside
Bagging insulation?
Ok before I seal up the belly pan do you think this is a good or bad idea? Plastic wrapped insulation to prevent getting wet from whatever source. Thanks, hoping I can upload pictures.
08-08-2017, 01:45 PM
1960 28' Ambassador
1998 25' Safari
Avonton
, Ontario
If you're not going camping in the middle of winter, the best idea is to leave out all the stuff the mice like to play in. I never replace insulation in the belly and have not noticed any reason to have it there.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
08-08-2017, 03:57 PM
1964 26' Overlander
Ingleside
We will be living in it while we build our home in the mountains. 9000 ft that is why we need floor installation.
08-08-2017, 04:01 PM
1964 26' Overlander
Ingleside
Originally Posted by the rambler
ok before i seal up the belly pan do you think this is a good or bad idea? Plastic wrapped insulation to prevent getting wet from whatever source. Thanks, hoping i can upload pictures.
08-08-2017, 04:44 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The very basic issue with doing anything like this:
If you make it tough for water to get in, you also make it tough for water to get out. It takes longer to get wet and may never dry out ....
08-08-2017, 05:03 PM
1964 26' Overlander
Ingleside
Thanks Bob, that's what I was thinking too on second thought, and was looking for some confirmation probably not a good idea. So better to seal everything as good as possible. Thanks for replying.
08-08-2017, 07:16 PM
1981 31' Excella II
New Market
, Alabama
You don't want to do that. It will eventually get soaked and stay that way. I would use 2" rigid foam with a slight separation between it and the floor so water can get out if it gets in. Leave a path for water to get out. You will loose the most heat through the shell since the ribs conduct heat well. The radiation barrier shiny bubble wrap would be good to put over the windows when it is really cold. The good is that it will heat up quick in the sun.
Perry
08-08-2017, 07:39 PM
1979 23' Safari
Wayland
, New York
Use rock wool insulation instead of fiberglass, it's easy to use down there, water repellent, mold resistant, and rodents don't like it.
08-09-2017, 12:41 AM
1964 26' Overlander
Ingleside
Thanks so much guy's now I have a better solution and peace of mind. Steve
08-10-2017, 05:59 AM
1988 25' Excella
Rural
, Vermont
I'm planning to use rock wool. What are people's thoughts on a few strategically placed, screened, small drainage holes in the belly pans?
08-10-2017, 05:40 PM
1981 31' Excella II
New Market
, Alabama
I would think rockwool would absorb water also consider the weight aspect of it. How much does it weigh compared to foam? Can you tape seams to reduce air flow?
Perry
08-10-2017, 06:01 PM
1994 30' Excella
Mississauga
, Ontario
If you tow your trailer in the rain it will get wet in there. Fiberglass insulation sags from age and vibration. Some will undoubtedly be in contact with the belly pan. Then it wicks up to the plywood floor.
My next major job is going to be removing all of it.
Al
Al and Jean
TAC ON-3
08-10-2017, 06:49 PM
1979 23' Safari
Wayland
, New York
Keep it from laying on the belly pan directly and some small drain holes will be fine. Kee them small, 1/8" ish.
Rock wool is hydrophobic and doesn't hold water, weighs slightly more than fiberglass.
A couple inches of rigid foam would definitely be my choice. Doesn't stop critters though.
