Greetings airstrmkids!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by airstrmkids
Hello,
I have a 1969 Airstream and the backend of the trailer is drooping. I was looking under the backend and I noticed that the frame has been drooping. When I jack up the frame from behind the bumper the bumper raises.
I would like to know if anyone else has had this problem and if anyone has gotten the frame fixed to repair the drooping and how much it cost approximately.
Thanks!!!
I agree that you likely have rear end separation. When the bumper moves independent of the body, you have the primary indicator of rear end separation.
I experienced the same thing with my '64 Overlander and had it repaired at a shop not too very far from you.
Ace Fogdall RV in Cedar Falls, IA performed the repair a little more than ten years ago and it continues to perform as intended. I believe that the repair was around $1,700 back then. Ace Fogdall RV was an Airstream dealer back then - - today, they are an authorized Airstream Repair Center.
Good luck with your investigation!
Kevin
