Old 02-25-2014, 10:16 PM   #1
1959 22' Caravanner
[B]Marine Grade and Pressure Treated Plywood[/B]
Has anyone heard of a problem using pressure treated plywood against the aluminum wall channel?
What replacement floor material would you recommend??
JimCat2000 is offline   Reply With Quote
Old 02-26-2014, 03:52 AM   #2
Baltimore , Maryland
never use pressure treated. It will cause you serious issues with the skin, is toxic stuff, and is full of voids. It is never felt either.
Old 02-26-2014, 05:07 AM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Like Frank said, never use pressure treated plywood anywhere near an Airstream. It has a bunch of nasty stuff in it including copper.
I recommend you use the highest quality marine grade plywood you can afford.
The best I've found is Joubert Marine grade.
Aquatek, Hydrotek are also high quality products.
You want something that meets BS 1088
Lance
Top is offline   Reply With Quote
Old 02-26-2014, 07:55 AM   #4
Muskie's Avatar
1959 24' Tradewind
collingwood , Ontario
I agree, there is no free lunch when it comes to the trade off for wood rot and for your health. Why they still make playgrounds for kids with the stuff is beyond me.
Those that think they know don't know, those that know they don't know, know.
Muskie is offline   Reply With Quote
Old 02-26-2014, 10:28 PM   #5
1959 22' Caravanner
OK, thanks. Joubert is available locally. Thanks, fellas!!!
Old 03-27-2014, 04:18 PM   #6
1968 17' Caravel
Cape Girardeau , Missouri
Treated generations of plywood
There have been several generations of treatment chemicals, some very bad ones have been rendered obsolete. The current one is manufacturer certified for aluminum contact above ground.
The blurb at my local Menards says:
This lumber has been pressure treated for above ground (AG) applications. AC2 brand treated wood products use MicroPro™ technology,.... MicroPro™ technology offers many benefits including significantly improved corrosion performance. MicroPro™/AC2 technology is the first treated wood process to be certified under Scientific Certification Systems Environmentally Preferable Product (EPP) Program based on life cycle assessment....
  • Environmentally friendly
  • MicroPro™/AC2 treated wood is NAHB Research Center green approved
  • Lighter, more natural wood appearance
  • Improved painting and staining qualities
  • Better corrosion resistance for code-approved fasteners and hardware
I am going to use some on my 68 Caravel.
DRitter is offline   Reply With Quote
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 06:29 AM
When did AS use OSB flooring (Oriented strand board)? Aage General Repair Forum 88 02-07-2015 12:20 PM
Please help settle this! Mr Wemmick Tow Vehicles 68 12-05-2011 03:59 PM
Checking air pressure xo1rider Tires 21 11-22-2011 01:58 PM
