Old 09-21-2012, 12:31 PM   #1
1965 22' Safari
Nipomo , California
Axle Replacement
Can anyonehelp with information on an axle replacement for a 1965 22' Safari (it is a single axle).
Any info including approx costs would be appreciated.
Bill R.
Central Coast, CA
wrinehart is offline   Reply With Quote
Old 09-21-2012, 02:18 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I feel comfortable recommending Colin Hyde for your axle needs. He can be contacted at (518) 578-7772. He spec'd out my axle for me and had it drop shipped to a local shop in my area to do the work.
His web site: https://sites.google.com/a/colinhyde...me/about-colin
MICHAEL
Old 09-21-2012, 05:53 PM   #3
Bill R.
Central Coast, CA
The freight from California will be considerably cheaper, than from Indiana.
Old 09-21-2012, 06:13 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I'd give Colin a call. He is the only one able to order OEM Henschen axles now, and he is the only one we use for Airstream axles.
I've tried getting Dexter axles from Redneck, but after having to return 3 sets of axles because either the brackets were mounted wrong, starting angle was wrong, shock brackets are not available and had to be welded on after delivery, ez-lube hubs instead of standard, I swore I'd never get Dexter axles again unless they made some radical changes (or I had a gun pointed at my head). So far, neither has happened. If someone inists on selling you Dexter axles, make sure you are aware of their return policy, in case you have problems like I have had multiple times.
Old 09-21-2012, 06:31 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Information
Bill R.
Central Coast, CA
Hi Bill,
There are a few different places you can get axles. As a commercial member of this forum I can't quote what it will cost. I can tell you that I highly recommend you shop around and take everything into consideration like
-axle cost
-customer support pre and post sale
-cost of shipping
-ease of installation
-shock brackets either already installed, loose and needing to weld on or cut the old shock brackets off and weld on the new axle.
I have bought many axles from Colin Hyde and I highly recommend him and the axles he sells.
There are many threads here on axle replacement. I would point you to this thread to start your reading.
Lance
Top is offline   Reply With Quote
