Old 11-24-2017, 08:01 AM   #1
1976 25' Tradewind
Loveland , Colorado
axle 3500 vs 5000
Hello,
As I am correcting some rust issues and replacing some out-riggers I will change out my axles too. I mean they are 40+ years old. It is a 1976 25' Land Yacht. I have different suppliers saying that the axles should be, 3500 and 5000 lbs. So my question is has anyone put in the Dexter 5000 lbs axles on a 25' AS? Did you have any issues with (rivet shear) or anything? Also some suppliers say to add the shocks and others say they are not needed? Dexter says they only put them on if requested for AS units and they are not needed based on the design.
Any thoughts on this long but needed question(s)?
mbbarnhill2 is offline   Reply With Quote
Old 11-24-2017, 09:48 AM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Why would you want to put 5k axles on?
My later and heavier 25 came with 3200 lb and I replaced with new 3500 lb
Having 10k worth of axle capacity on a trailer that might gross at 5 or 6 k would make it ride like brick I would think
AlinCal is offline   Reply With Quote
Old 11-24-2017, 09:58 AM   #3
1976 25' Tradewind
Loveland , Colorado
I guess that's my question, as the GWR is 5800 but the supplies are saying 5000 lbs axles. So I am just checking out others thoughts and if anyone has done this.
Old 11-24-2017, 10:02 AM   #4
1976 25' Tradewind
Loveland , Colorado
also I just got a book and it says the axles are 2600??? Anyway just checking this out.
Old 11-24-2017, 02:45 PM   #5
AlinCal's Avatar
1991 25' Excella
There should be an ID tag on your axle with rating info.
Mine was hard to find but on forward face of axle beam
Old 11-24-2017, 02:50 PM   #6
AlinCal's Avatar
1991 25' Excella
2600 sounds right for 5800 gross.
2600 + 2600 + 600 tongue = 5800
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
Old 11-24-2017, 03:18 PM   #7
Vintage Kin
Fort Worth , Texas
My full frame 35' Silver Streak only uses 4,500-lb axles. And could have been 4,000
Old 11-25-2017, 11:27 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Talking
Originally Posted by mbbarnhill2 View Post
Hello,
all you need is ......3500.......5000 would be overkill
Old 11-25-2017, 01:57 PM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
mbbarnhill2
I agree. I just replaced my axles in my 66 Tradewind. My original axles were either 2600 or 2800 lbs. My loaded axle weight is only 2100 lbs. I ordered 3500 Lb axles reduced to a design loading of 2500 lbs. Please note that the Dexter 3500 Lb axles require a 5 lug wheel, so that you will need to buy new wheels. For more details you can look at my thread- Dan’s 66 Tradewind Improvements.
Dan
Old 12-03-2017, 05:39 PM   #10
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
The heavier axles would make the trailer ride very rough. I have a utility trailer with 2-6000# axles and it will make you sick to your stomach pulling it empty because it bounces so much. Put a load on it and it pulls like a dream.
AlbertaBound is offline   Reply With Quote
A&E Travel Awn 5000 uwe Awnings 11 07-05-2016 07:33 AM
Hyundai Veracruz #3500 vs. Hyundai Santa Fe LWB #5000: Why the difference? Dia Tow Vehicles 0 10-21-2013 02:19 PM
An axle is an axle is an axle? Globie64 Axles 45 01-01-2012 01:25 PM
5000# Axle? zlee Axles 4 11-29-2011 07:32 PM
New 5000# axle came today my1ststream Axles 3 05-18-2010 05:54 AM
