Old 03-23-2014, 02:32 AM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Attach U channel without dropping belly pan?
I have a section of floor I replaced which needs to be attached to the U channel. I have the inside skin off, but would really like to not drop the belly pan for many reasons. Is there a way to attach the U channel to the new plywood and frame without dropping the belly pan?
thinktankair is offline   Reply With Quote
Old 03-23-2014, 03:51 AM   #2
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Short answer not in my opinion but just my opinion. Save some time and frustration and do it right the first time. Drop the belly pan.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 03-23-2014, 06:46 AM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Drill straight down through with a 1/4 inch drill, including the belly pan. Enlarge the hole in the belly pan to about 3/4 inch with a step drill.
Push a 1/4 inch carriage bolt up from the bottom and install a flat washer , lockwasher and nut . Lock tite doesn't hurt.
The belly pan holes are not noticeable and can be plugged with a hole plug or simply covered with a small piece of aluminum tape.
Dropping the pan on a 60's trailer is a major job.
I did all needed frame repairs, insulation repairs etc from above on my 61 before piecing in the new floor.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 03-23-2014, 07:12 AM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I was able to do mine without dropping the pan. Secured it with self tapping screws down into the frame, and smaller screws through the channel into the new wood. Has held up fine for ten years.
Stephanie
Old 03-23-2014, 08:19 AM   #5
1961 16' Bambi
Thank you so much rick! What length bolt did you go with and what was the spacing? Every 5 inches or so? Rick, I so appreciate you saying it is a bear to drop the pan on the teailer. I thought the same and was doing well until this. Stef - did you secure the U channel into the wood into the wood only and that worked? I'm assuming your self tap went went down into the frame? BTW - my restoration blog is bambiairstream.com thanks all of you!
Old 03-23-2014, 09:43 AM   #6
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
When the trailer was built the floor was secured with bolts with nut and then peened over so the would not unscrew.
Now days you can buy self threading floor bolts on Ebay or even in small quantities from tractor supply. They are a hardened , fine thread screw and seem to hold quite well.
some even pre drill although the ones I used required drilling a 7/64 hole and then power driving them.
I probably should mention the technique with the holes in my previous post was onlu used around the edges where the belly pan was to tight to reach in under the new pieces. The self threaders were used everywhere else the floor fastened
I used many more fasteners than Airstream did and their setup lasted 50 years
13 Ram 2500 TD
Old 03-23-2014, 02:52 PM   #7
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
The channel was secured only to the wood, and the wood was secured to the frame. Just as Rick says, I used a high quality self tapping screw, and more of them than airstream used, and my trailer was 40 years old when I had to replace the front half of the floor. I think the repairs should hold up just as well.
Stephanie
Old 03-23-2014, 02:55 PM   #8
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
Worst case scenario and you need to get to the bottom side. You can pull it up on ramps unzip the belly pan seam, drill out the rivets on the flats and lower the sections enough to reach out to the edge from the bottom side. You may or may not have to cut and patch near the axle to get the pan sections low enough.
putback is offline   Reply With Quote
I was afraid of the belly pan Dingo Girl 1966-68 Caravel 26 10-05-2016 03:27 PM
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Belly Pan replacement canoeman Repairing/Replacing Floor &/or Frame 2 02-10-2012 02:37 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
