01-15-2017, 07:16 PM
1962 19' Globetrotter
canmore
, Alberta
Asbestos flooring tiles?? original airstream
I have an original 62 airstream are those asbestos tiles??
how do i find out?
01-15-2017, 07:26 PM
Retired.
, At Large
Welcome to the forum.
Generally, if the tiles are 9" squares, they are asbestos. If they are 12" tiles, they are not.
01-15-2017, 07:34 PM
canmore
, Alberta
thanks
01-15-2017, 07:36 PM
2018 27' International
Southeastern MI
, Michigan
Bean-e-doo solvent will remove them. It's non flammable, vegetable based.
2018 International Serenity 27' FB
Michelin 16” tires
Hensley Arrow hitch
Tow Vehicle: 2020 F-350 6.7L Diesel
01-28-2017, 05:22 PM
2016 30' Classic
Hinckley
, Ohio
Wet them down so it does not become airborne. You can just though them in the trash, because it is encapsulated within the tile. It when they break that it releases the asbestos
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
03-25-2017, 03:08 PM
alfred
, New York
a question for you.
i am replacing my subfloor around the door and also in the rear (64 globetrotter). the asbestos tiles are hard and fast on the subfloor. po removed some and loots to have given up on taking all the tiles off and put sheet of luan over everything then lineoleum floor on top. i'd like to remove all the tiles and get down to a good subfloor, then top with a flooring yet to be determined.
to take the tiles off, would you wed the tiles, and then try to get a crow bar underneath to rip them off the subfloor? anyway easier? not the strongest, but i am strong for 5'3" old woman, and still quite handy. thanks for your time and consideration.
diane
03-25-2017, 03:28 PM
1967 17' Caravel
Oak Creek
Be sure to wear a respirator or at least a mask when removing the tiles. Seems I read somewhere on the forums some have used a heat gun to loosen them. I personally used one of those shingle shovels that roofers use to get shingles up. I ground down the edge of the shovel so it was sharper.
I was lucky that the majority of my asbestos laden tiles were loose. Only had a handful of sticklers.
Good luck with your project.
Go girl power!
03-25-2017, 03:58 PM
alfred
, New York
thanks! before i posted, i did take a skill saw to the floor, had it set too deep and cut thru about 9 of them underneath the lino/luan layer before the brain power kicked in "asbestos?" duh.....
just took shower, washing clothes and off to lowes for respirator. totally agree with you about girl power, go sister!!!!!!!!!!!
di
04-14-2017, 03:07 PM
1967 17' Caravel
Oak Creek
di
How's the project coming along?
04-15-2017, 05:21 AM
alfred
, New York
hi!!!!!! so far slow but good. about 3/4 of the tiles removed. but got redirected by the floor rot. of the 2 rot areas in the front on either side, i've cut out the rot on the driver side and made a cardboard template. removed the frig and got all that rot area exposed. after patching the first area, will move to the door/frig area. what i am most excited about is the removal of all the backend fixtures (tub, toilet, sink, hot water tank). what an ordeal, but i now see the extent of the rot in the trailer. removing all those fixtures had me staring at a tangled yet working mess of wires and the univolt system (next winter i suspect) a former student helped me with the back end, thank goodness.
i decided the best strategy for me was to start with the simplest, and have various states of repair going on at the same time.... hoping that the learning/fixing process would make for smarter and quicker work.
and spring is here!!!!!! ah..... the call of the geese speaks to the call of the roads!
