Old 04-09-2016, 11:36 PM   #99
1962 22' Safari
Brooklyn , New York
What's yr thinking behind painting the interior of the exterior skins?
my current shell-off: http://www.airforums.com/forums/f44/...ht-144874.html
skyclad is offline   Reply With Quote
Old 04-10-2016, 01:15 PM   #100
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I bought Click image for larger version
Name:	ImageUploadedByAirstream Forums1460311801.365801.jpg
The theory is that it's suppose to help insulate and provide a thermal break. I'm also spray foaming for insulation. Basically it's ground up ceramic- it's very fine. Just add to your paint. It was 50 bucks for 5 gallons. Why not give it a shot. I'll update on performance. I did not paint the other end cap yet so I maybe be able to test temp on either side
Matt
rugjenkins is offline   Reply With Quote
Old 04-16-2016, 10:04 PM   #101
rugjenkins's Avatar
1975 Argosy 28
Name:	ImageUploadedByAirstream Forums1460862025.612818.jpg
ID:	260883Click image for larger version
Name:	ImageUploadedByAirstream Forums1460862060.492290.jpg
Installed the new door lock set today! The old one was leaking like crazy. The piece of wood had dead termites in it! No more leaks now and it came out great👍😄
Matt
Old 06-09-2016, 11:12 PM   #102
rugjenkins's Avatar
1975 Argosy 28
I never really like the old molded abs tail light housing on my argosy! So installed these. They give a cleaner look and they are led.Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531825.133112.jpg
ID:	264135Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531838.568431.jpg
ID:	264136Click image for larger version
Name:	ImageUploadedByAirstream Forums1465531855.868948.jpg
I had to cut big holes . This is an easy mod but not for the squeamish😄
Matt
Old 10-20-2016, 02:37 PM   #103
Houston , Texas
Matt, this is a dumb question, is your subfloor slightly smaller to fit inside the steel tubing that you welded to the outriggers? If that is the case, does any of the C-channel from the shell get bolted to the subfloor or does is sit squarely on the tubing?
Gary
Disable is offline   Reply With Quote
Old 10-24-2016, 10:04 AM   #104
rugjenkins's Avatar
1975 Argosy 28
No dumb questions here👍 the c-channel is completely removed. The shell (the ribs) are bolted to steel stubs welded on the frame. The subfloor sits inside the steel tubing frame. I raised my shell about 3 inches higher than original. The new belly pan is the riveted to shell to give it a clean look. I didn't like the original setup of the shell on subfloor with the belly pan overlapping the shell. (I felt it was improper engineering- it was made to fail) so I took the time to underlap the belly pan so that the water would shed off as it does on a house. Plus the floor can be removed now without taking the shell off. I like it. It's a better common sense design. Click image for larger version
Name:	ImageUploadedByAirstream Forums1477321185.141868.jpg
Here you can see the new floor, steel stubs/rib connection, steel tubing frame and new belly pan attached to the shell.Click image for larger version
Name:	ImageUploadedByAirstream Forums1477321406.610413.jpg
Here is a pic of the outside with it all back together belly pan and all
Matt
Old 11-27-2016, 07:18 AM   #105
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Thanks and a question
Matt, Great thread we are just in the planning stage and have found your thread very helpful. How did the ceramic addition to the paint go? Did you roll or spray? have you noticed any changes in temp? Are you DIY the spray in insulation or having it done?
Thanks again looking forward to following your progress.
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
Old 11-27-2016, 08:16 PM   #106
rugjenkins's Avatar
1975 Argosy 28
The ceramic was rolled on. There is a noticeable difference on surfaces with the ceramic paint. It's one of the cheaper upgrades. The whole camper is DIY.👍😄 I used 2 methods for the insulation: 2 part spray foam and great stuff with a triangle nozzle. 1/3 was done with the 2 part spray foam. The other 2/3 with the great stuff from a can. I prefer the great stuff from the can. It was more uniform with no hazards to my health! Plus it was 1/2 the cost!
Matt
Old 12-26-2016, 08:41 AM   #107
GoNomad's Avatar
1975 Argosy 28
How is it going?
Just wanted to check in and see how your project is going? We just got started with the gutting of the bathroom to do floor repair and plumbing/electrical upgrades.
Also could you add your information and Vin Number to the Argosy database? it can be found here http://www.airforums.com/forums/f227...se-106682.html
Hope all is well
Nick & Holly
Old 03-30-2017, 04:05 PM   #108
rugjenkins's Avatar
1975 Argosy 28
All is well, home projects take priority so work on the camper stopped. Electrical, plumbing and insulation are done! ready to place interior panels. Not sure if I will reuse the interior end caps. Possibly of either wood or aluminum 13 panel. Why do easy, right?
Matt
Old 03-30-2017, 04:09 PM   #109
rugjenkins's Avatar
1975 Argosy 28
I'll post pics of the finished insulation and my "save a ton of money method" for spray foam insulation
Matt
