Old 01-30-2016, 08:53 PM   #57
1975 Argosy 26
Tulsa , Oklahoma
Sounds like you are making great progress. Keep it up !
I got a start on dropping the belly pan on my Argosy last weekend, hoping to finish dropping it tomorrow. Some welding will definately be required.
Also, those buck rivets don't come out nearly as easy as the smaller pop and intermediate rivets do :-)
Thanks for the tip on the 'Ace galvanized metal and aluminum primer'. I'll have to take a look at that.
DDOK is offline   Reply With Quote
Old 02-01-2016, 11:43 PM   #58
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Finally done stripping the paint!!
It seems that if I say 1 day to do something and it takes 3 maybe I should say I'll be one with the camper in 1 week!😁
Matt
rugjenkins is offline   Reply With Quote
Old 02-04-2016, 10:12 AM   #59
rugjenkins's Avatar
1975 Argosy 28
Finished priming the belly wraps. I sanded with 150 grit then sprayed with ace gal and alum primer. I'll post a pic tonight.
Matt
Old 02-07-2016, 07:54 PM   #60
rugjenkins's Avatar
1975 Argosy 28
Tanks and plumbing drains are installed!!Click image for larger version
Name:	ImageUploadedByAirstream Forums1454896486.853578.jpg
Matt
Old 02-07-2016, 09:29 PM   #61
1962 22' Safari
Brooklyn , New York
Not sure what we're looking at here. Are those black things your tanks? They look crazy thin! What type and capacity?
my current shell-off: http://www.airforums.com/forums/f44/...ht-144874.html
skyclad is offline   Reply With Quote
Old 02-07-2016, 09:39 PM   #62
1975 Argosy 26
Tulsa , Oklahoma
Looking Nice !
I just finished dropping my belly wraps today. Pan and Belly wraps are off on mine. I just need to remove a little more flooring and start cleaning up the frame.
--DD
Old 02-07-2016, 09:54 PM   #63
rugjenkins's Avatar
1975 Argosy 28
Back- 23 gal black tank- poly
Center- 32 gal grey tank-poly
Front-27 gal grey tank- abs
Not thin at all- just the pic
Matt
Old 02-07-2016, 10:08 PM   #64
rugjenkins's Avatar
1975 Argosy 28
Correction: center is a 27 gal poly. PPL rv parts has it labeled wrong on there website
Matt
Old 02-07-2016, 10:13 PM   #65
1962 22' Safari
Brooklyn , New York
Ok thanks. I haven't figured out my tanks yet but want to plan ahead. Mind sharing more pics of how you installed them?
Old 02-11-2016, 07:47 PM   #66
rugjenkins's Avatar
1975 Argosy 28
The floor is screwed to the 2x4's running down the center. Drilled and installed an elevator bolt. I tried to get it flush with floor to see if I need to use a forcner bit to countersink. I broke the elevator bolt! Yep I will need to use the bit to make them flush. I used lock nuts. I was surprised to the holding power😄
Matt
Old 02-13-2016, 07:49 AM   #67
rugjenkins's Avatar
1975 Argosy 28
Por-15 all the elevator bolts and nutsClick image for larger version
Name:	ImageUploadedByAirstream Forums1455371346.018990.jpg
Matt
Old 02-14-2016, 06:21 PM   #68
rugjenkins's Avatar
1975 Argosy 28
Floor is installed!Click image for larger version
Name:	ImageUploadedByAirstream Forums1455495528.970834.jpg
These are elevator bolts, Nyla nuts and self tapping screws that brought it together.Click image for larger version
Name:	ImageUploadedByAirstream Forums1455495641.313107.jpg
ID:	257273 all if these can be ordered on vintage supply
Matt
Old 02-14-2016, 07:36 PM   #69
1962 22' Safari
Brooklyn , New York
Looking great! Congratulations on this milestone. I hope to follow close behind!
Old 02-15-2016, 10:48 PM   #70
1975 Argosy 26
Tulsa , Oklahoma
Matt: Quick Question - Did you remove the wheel wells entirely? If so, how dow they come out?
Also, what's the trick for removing those bolts from the floor? Did you use an Angle grinder with a cutoff wheel ?
You are a month or two ahead of me in the redo work you are doing, so following this thread is a perfect tutorial ! Thank you for posting and sharing all this great information.
