10-17-2013, 05:28 PM
#21
1975 Argosy 28
Springville
, Alabama
my new floor plan
Welding is coming along great. I'm almost done in the frame fab department.My wife and I didn't like the old floor plan (who likes to keep things simple, right I am at a critical point in the project- deciding what goes where. So after a week of drawing a dozen layouts, this is what we had decided on. Now I can order tanks, finish welding and por-15 before it gets to cold. My goal is an aluminum
tent by spring.
I'm putting in bigger tanks. Valterra 8x16x54. Relocating them closer to the axles.
10-19-2013, 10:14 PM
#22
1975 Argosy 28
Springville
, Alabama
Spent two days pouring over darkspeed's tread, a must read for all.
So here is what I have come up with the eliminate airstream design flaws.
1.5 tubing band welded to outside of outriggers. Then stubs welded to band then bolted to ribs, just like darkspeed's. It takes care of the belly pan overlapping the shell. That way everything sheds water the proper way. Plus subfloor can be installed when ever and in the future replacing bad spots (if any) won"t be an issue. No taking shell off or removal of belly pan.
10-20-2013, 07:18 AM
#23
I am glad that you are saving her, big thumbs up!!!!!!
Where are you putting the furnace and duct work?
I am looking to relocate a heating duct, because it is aimed at the dinette side, that is about 5 inches away. The heat damaged the covering.
10-21-2013, 06:05 PM
#24
1975 Argosy 28
Springville
, Alabama
The camper was gutted when I got, so I'm not real sure where it was located. I may not put one back in. I'm thinking of a dual unit on the a/c.
Matt
10-26-2013, 09:50 PM
#25
1975 Argosy 28
Springville
, Alabama
Making curves and banding the outer edge.
Matt
10-26-2013, 09:57 PM
#26
1975 Argosy 28
Springville
, Alabama
Great news, my other 2 quarts of por-15 are no longer lost. With the extra metal it will come in handy.
Matt
11-06-2013, 11:19 AM
#27
1975 Argosy 28
Springville
, Alabama
Outside 1.5 steel tubing band and curves ...done.
Now I have to come up with a solution to the dreaded rear storage compartment. Suggestions anyone?
Matt
11-22-2013, 09:59 AM
#28
1975 Argosy 28
Springville
, Alabama
Made new steel hold down plate for the rear. Made the same size as the front.
Matt
11-22-2013, 10:06 AM
#29
1975 Argosy 28
Springville
, Alabama
Finally finished stripping old paint off the frame last night. Used 3 methods.
1. Flap disc on angle grinder - good
2. Sandblasting - less than good, big mess.
3. Heavy duty wire wheel on angle grinder- best.
All are time consuming. Suck it up and press on.
POR-15 here I come!
Matt
11-22-2013, 10:14 AM
#30
1977 29' Ambassador
Oxnard
Are you re-painting or polishing the Argosy? Did the wire wheel scratch the aluminum?
11-22-2013, 01:55 PM
#31
1975 Argosy 28
Springville
, Alabama
The plan is to repaint with new color scheme. I don't want to polish all time. Don't use a wire wheel on the aluminum. It will scratch it really bad and cause much fussing and anger. Use stripper. On mine the original paint is half gone so... Less work. I like that.
Matt
01-14-2014, 10:12 PM
#32
1975 Argosy 28
Springville
, Alabama
Received one of the gray tanks this week. Ready to fab tank mounts near axles. I also cut all the flooring. I'm trying to get all the metal fab finished before I por-15. Aluminum tent here I come.
Matt
01-15-2014, 09:22 AM
#33
1975 Argosy 28
Springville
, Alabama
Question: what is the measurement of the toilet flange from the wall? My guess is 1 ft. Any help is greatly appreciated.
Matt
01-15-2014, 10:38 PM
#34
1975 Argosy 28
Springville
, Alabama
Need help
Matt
01-15-2014, 10:40 PM
#35
1975 Argosy 28
Springville
, Alabama
I don't like the new cell phone app. The old one was better. This one has issues.
Anyway it won't post the newest reply. Need help on above post. Thanks
Matt
01-25-2014, 02:55 PM
#36
1973 Argosy 24
Frostproof
I wish I'd seen your post while we still had the new toilet off--I can't get a good measurement now, regrettably. Will an approximate center point from rear wall help at all? I'd recommend choosing your toilet and going from the measurement from the factory. We had to buy a second toilet because the first wouldn't fit the dreadful ABS toilet surround--but had we done more research, we wouldn't have goofed. Measure twice, cut once! Your work is admirable, Rug.
Carolinda
1973 Argosy 24
TV - 2011 Tundra
Now at the getting much prettier stage!
03-10-2014, 06:57 PM
#37
1975 Argosy 28
Springville
, Alabama
Update: ok still working on the frame. Welding tank mounts in, (4) almost done. I had to make several frame brackets to hold the tank supports- 2 x 3 x 3/16 angle. 1 black, 2 gray, 1 fresh water. I'll post pics soon.
Matt
04-22-2015, 02:47 PM
#38
1975 Argosy 28
Springville
, Alabama
Frame done, por-15 done, shell semi bolted to frame, gantries disassembled and washed camper(hasn't had a bath in 5 yrs)
Purchased belly pan aluminum and buck rivet gun and supplies.
Matt
05-01-2015, 07:12 AM
#39
1981 31' Excella II
New Market
, Alabama
How about some photos. Sounds like you are doing well.
Perry
08-17-2015, 08:21 PM
#40
1975 Argosy 28
Springville
, Alabama
Bolting shell to frame. Drill hole, go to store to get more bits, drill more holes, por-15 bolts and nuts.
Matt
