08-28-2010, 02:45 PM
1972 31' Sovereign
Lexington
Are these weepholes in our C-channel?
We're putting the rest of the elevator bolts in the floor this weekend, and have "discovered" what looks like weepholes in the outer bottom edge of our C-channel all the way around spaced a couple of feet apart. No way would you be able to get an elevator bolt in them since they are in the "corner", but they are that size. Weren't for screws either for the same reason. All we can come up with is weep holes, but why and should we leave them open or Vulkem them closed?
Kay
08-28-2010, 03:59 PM
1960 33' Custom
Athens
, Georgia
Can you get a photograph?
08-28-2010, 04:05 PM
x
XXXX
, XXXX
Kay could they be rivet holes from the wrap or lower belt trim? I can't imagine A/S drilling weeping in the channel unless they wanted the belly to fill up with water. Wait a minute yes I can.
08-28-2010, 04:28 PM
1972 31' Sovereign
Lexington
Here's a pic of one of the mystery holes. They are too large for a rivet, and they acutally go down thorugh the bottom of the c-channel. They are spaced about every 24 inches all the way around the trailer, including the curved c-channels at the front and back.
08-29-2010, 08:29 AM
1972 31' Sovereign
Lexington
Bumping to see if we can get an answer.
08-29-2010, 08:48 AM
1971 27' Overlander
Antlers
, Oklahoma
My overlander had the same holes.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
08-29-2010, 08:53 AM
x
XXXX
, XXXX
Spped holes to make it go faster. lol
08-29-2010, 08:56 AM
1960 33' Custom
Athens
, Georgia
Interesting, I still have no idea, but it's odd that they are in the radius of the channel. I'd leave them open though as water in the bely pan area is probably safer than water in the walls.
08-29-2010, 09:33 AM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
In the early 70's they discovered that the mice living in the walls were dying from asphyxiation, so they added these little "breather" holes to make sure they were getting enough oxygen . . .
Actually I do think it was "a measure" they took to deal w/moisture (maybe not actual water draining but to help w/condensation). If it's cold outside and hot/warm inside then I think it's always going to be moist in the walls which promotes the dreaded galvanic action between the aluminum and the fasteners. On my trailer the Aluminum Channel was completely corroded away at every bolt connection (to the end of the outriggers), and at each screw it was almost corroded through.
I was thinking of adding holes to my new Channel, so I'm curious to know what yours looked like at each fastener. Did the holes help?
Thanks for posting your project.
MarkR
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
08-29-2010, 10:56 AM
1971 21' Globetrotter
Arvada
My 71 GT did not have them. Not a bad idea though.
08-29-2010, 11:54 AM
1972 31' Sovereign
Lexington
There was a little corrosion in the C channels at the elevator bolt holes around most of the trailer. Just enough so you knew where the elevator bolts had been, but not enough to worry about. The C channel was worse around the back where we also had had leaks and there was virtually no floor either.
If we get mice in the walls, we certainly DON'T want them dying in there! Mice reek with a very distinctive smell when they die (I can smell them a mile away). Yuck.
Now we'll look for some itty bitty teeny weeny little fans to install in the holes so we can improve ventilation and keep the mice alive! Any ideas where we can find some?
Kay
08-29-2010, 01:50 PM
Port Orchard
Kay
It would probably be easier and less costly to rig up a large fan in a plenum and then run a hose from each hole to the plenum. If any mouse did die, you could reverse the fan and suck all the smell out through the holes.
Regards,
Ken
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
C Channel How-To
roadtrip07 |
Repairing/Replacing Floor &/or Frame |
3 |
07-04-2010 06:49 AM |
C Channel
1bbboomer |
9 |
06-29-2010 07:52 AM |
u-channel down against the outrigger?
gwchitty |
17 |
01-15-2008 09:18 PM |
channel question
robbp |
1 |
08-29-2006 11:39 PM |
History Channel
markdoane |
Off Topic Forum |
0 |
06-25-2005 12:23 PM |
