Old 04-22-2014, 10:01 PM   #1
1975 25' Tradewind
Conifer , Colorado
Anyone tried COREtec plus vinyl plank flooring?
We're trying to decide on a flooring for our 75 Tradewind. Has anyone heard of this? We just discovered COREtec plus vinyl plank flooring by US Floors. It sounds good. Advertised to be an entirely new category of vinyl called Engineered Luxury Vinyl flooring. Has 4 layers. Constructed with WATERPROOF extruded core board. Will never swell when exposed to water. COREtec Plus is inert and dimensionally stable, says it will not expand or contract. Drop and click, glueless. We talked to someone at a Carpet/Flooring store about it, but they don't really know trailers. Check it out at usflooringllc.com They have wood flooring styles as well as some stone looks. Nice look.
dirtman is offline   Reply With Quote
Old 04-23-2014, 09:53 PM   #2
millertimeUS's Avatar
1976 25' Tradewind
We just bought some vinyl plank floating floor from lowes for the same reason. Waterproof and should wear like iron. Have a ways to go on the rear before it goes in though....
Matt
millertimeUS is offline   Reply With Quote
Old 04-23-2014, 11:00 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I'd like to see some in real life, but it doesn't look like they have much of a distribution network.
Old 11-22-2016, 07:21 AM   #4
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Anyone tried Coretec Plus in the last 2 years since this thread was started? I'm looking at samples today.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 11-22-2016, 07:51 AM   #5
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I looked at it and decided to not use it.
I did not like that they are deceptive in advertising. They call their company USFloors, but if you look at their packaging or on their material specification sheets it says "MADE IN CHINA".
Alan
Old 11-22-2016, 01:59 PM   #6
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
This is what we used and couldn't be happier. Click lock but we glued it down. Click image for larger version
Name:	ImageUploadedByAirstream Forums1479848364.523666.jpg
ID:	275812Click image for larger version
Name:	ImageUploadedByAirstream Forums1479848380.959227.jpg
Name:   ImageUploadedByAirstream Forums1479848393.077836.jpg
Kemblkr is offline   Reply With Quote
Old 11-22-2016, 03:40 PM   #7
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I looked at it today. Nice stuff. I may go with it.
Old 11-22-2016, 09:05 PM   #8
Kemblkr's Avatar
It has a heavy wear layer so it has a lifetime residential warranty. It's about 8mm thick so hopefully I won't have to shim everything that once sat on the carpet. From what I can tell the carpet and padding was about 1/4" thick compressed.
I should be fully waterproof now!
Old 03-07-2017, 07:14 PM   #9
2003 25' Safari
Oro Valley , Arizona
We are newbies, just purchased our first, 2003 Safari 25' and are going to put in the Coretec.. My husband has Chemical Sensitivity and this brand is GreenGuard and seems to be Ok for him.
Ajlawcz is offline   Reply With Quote
Old 03-07-2017, 08:46 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by Kemblkr View Post
This is what we used and couldn't be happier. Click lock but we glued it down. Attachment 275812Attachment 275813Attachment 275814
What kind of glue did you use for the flooring? I used Allure click together vinyl flooring & have separation in one area. It happened this winter (we live about an hour from you straight west). I'm wondering if you had any separation this winter on your flooring? If not, I may have to follow suit & glue mine!Click image for larger version
Name:	flooring in cold weather ....ugh!.JPG
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-08-2017, 08:56 AM   #11
2003 25' Safari
Glueing Coretec
The glueing would be a big issue for me due to my husbands sensitivity. I am reading a lot of reviews with issues with this flooring, am now looking back into the Armstrong products. It also sounds as though the installer is key, which would not be me. We live in Tucson, so standing up to heat more important than cold.
Old 06-18-2017, 05:11 PM   #12
2003 25' Safari
We ended up using Marmoleum planks, click together, no glue
Old 07-25-2017, 08:23 AM   #13
1973 31' Sovereign
Milton , Delaware
My concern is expansion and shrinkage due to temperature differential. For example, we took a piece of 4" X 4" vinyl plank flooring from Home Depot; measured it with a micrometer; placed it in our freezer for an hour then measured it again. It shrunk 0.080"
If my math is correct, that means a shrinkage of 1.44" over 9'.
Totally unacceptable.
Hope this helps someone,
Richard
tartansailor is offline   Reply With Quote
Old 12-07-2017, 08:09 PM   #14
Can't Get There From Here , Maryland
I used COREtec flooring in a house renovation and really loved it. I wouldn't hesitate to use it in a house or a trailer. My AS reno will use their subsidiary company's product, SMARTCORE, at half the price per square foot, just because I don't think I need to spend that much. But if I had the budget, I would use COREtec.
elektrik is offline   Reply With Quote
Allure Traffic Master Vinyl Plank Flooring Chillbilly Floor Finishes 56 05-25-2017 07:33 PM
New carpeting and vinyl plank flooring JMSx2 Land Yacht/Legacy Motorhomes 12 05-20-2014 05:09 AM
Picture of vinyl plank flooring installed spaceghost65 Repairing/Replacing Floor &/or Frame 6 08-19-2013 11:37 AM
Wood Plank vinyl flooring wvabeer Land Yacht/Legacy Motorhomes 33 07-08-2013 05:13 PM
Has anyone tried this flooring? wannaroam Floor Finishes 164 10-18-2012 08:15 AM
