Old 01-29-2012, 02:34 PM   #1
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Anyone installed a frame stiffener kit?
1976 29' rear bath that has developed tail sag.
If I were to install a frame stiffener kit, do I have to remove the existing axle mounting plate (the one with the big holes that is welded to the frame just over the axles) or can I just bolt frame stiffener kit to the frame and leave the axle mounting plate in place?
Eagle & Bear is offline   Reply With Quote
Old 01-29-2012, 03:37 PM   #2
larry b's Avatar
1975 31' Sovereign
howell , Michigan
This should answer your questions regarding the installation,
larry b is offline   Reply With Quote
Old 01-29-2012, 06:08 PM   #3
1981 31' Excella II
Orlando , Florida
The question is why is it sagging? Is the frame still attached to the rear of the trailer? It is common for corrosion and floor rot to cause the rear end to separate. The frame is very week without the body to support it. The 70's model trailers seem to have the most problems because of adding a gray water tank without increasing the strength of the frame. Once the frame separates from the body, the frame will bend.
Perry
Old 01-30-2012, 12:47 PM   #4
1976 29' Ambassador
Perry ; reparing the rear separation is next.
Larry; That is the graphic I needed. Thanks
Old 01-30-2012, 01:06 PM   #5
The frame "beef up kit" is very nice.
But it will not do one single thing for rear end separation.
But it will waste your time and money and, add unnecessary weight to the trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
How can a bent frame be fixed? Eagle & Bear Repairing/Replacing Floor &/or Frame 7 03-02-2012 11:48 AM
Can I just spray the frame with undercoating? robwok Repairing/Replacing Floor &/or Frame 5 12-01-2011 10:25 AM
Frame Failure dmm9623 Repairing/Replacing Floor &/or Frame 9 08-12-2011 10:03 AM
frame reinforcement - rear end separation silversafari Repairing/Replacing Floor &/or Frame 1 03-17-2011 10:16 AM
The frame is ok ~ Patching the floor. LawChick Repairing/Replacing Floor &/or Frame 12 01-30-2011 02:39 PM
