Old 03-22-2018, 10:24 AM   #1
2018 19' Flying Cloud
Astoria , Oregon
Anyone had floor fixed in new Airstream?
I have new 19ft Flying Cloud Bamby that needs floor repair because of bump
in front of toilet. Cause is unknown, It's not water, could be tongue and grove
seam. My consern is they have to take out cabinets and a lot of other stuff so they can lift off the vinyl flooring to get to the problem and fix it.
What will the results look like? Lots of plumbing in that area. Are the cabinets
riveted to the inside aluminum? I don't like the idea to just live with it. I feel the bump every time I walk over it.
Thanks Steve
Steve Siler is offline   Reply With Quote
Old 03-22-2018, 10:57 AM   #2
Mount Dora , Florida
Have it done at Jackson Center.
I haven’t read anything good on here about Airstream service departments in the northwest.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 03-22-2018, 04:35 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
This is a tough one. Airstream puts the flooring down and then builds the trailer top of it. So, getting under rolled vinyl to repair the plywood means exactly what you suspect. They will have to remove everything in order to see what’s causing the bump. This is awful for a brand new owner and trailer to contemplate. Obviously, your call as to what you want done. JC can obviously take care of this but you live in Oregon and that’s a very long haul. Has the dealer been involved in a conversation about this defect? (There’s no way I would trust most dealers to completely strip out all of the interior of my brand new trailer and expect it to look factory perfect.) My solution (and this is just me), would be to remove the toilet. Then I’d take a utility knife and carefully cut out all of the vinyl flooring in the bathroom. Fix the offending bump. Then, I’d put in some really cool floor covering (maybe the wood look stuff they have at Lowe’s or Home Depot. I’d put a nice threshold piece where the new floor butts against the vinyl floor at the threshold into the bathroom. Many of us have changed out flooring in our trailers to something other than the stock light "fake wood" vinyl that Airstream uses. That’s what I’d do. I’m guessing you didn’t spot this defect on the PDI.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-22-2018, 06:26 PM   #4
LilBigfoot's Avatar
2016 26' Flying Cloud
London , Ontario
I have a 2016 26U with a small bulge in the flooring just outside the bathroom door. Looks like the techs slid a bathroom wall along the vinyl and stretched it as they moved the walls into place. Bothered me at first. Then it started coming and going as the weather changed here in Ontario. Thought I'd cut a slit in the bump and let the air out. Decided against that as water might get under the flooring should there be a leak.Now I just live with it and am thankful my Airstream doesn't have a leak anywhere. No way I'd want my new Airstream ripped apart again. Just imagine the unseen damage that could be done. I've had both the kitchen and bathroom counter tops taken out of my AS and I could not believe the sloppy job done on the install of the cabinets. Extra screw holes every where, missing screws in brackets, crooked supports. The advice given by BAB is the way I'd handle your defect if you can't live with it.
You're a long time underground!
LilBigfoot is offline   Reply With Quote
Old 03-22-2018, 07:03 PM   #5
Coeur d Alene , Idaho
Our daughter and her husband have a FC31 that they bought new in 2015. There was a small leak that they didn't discover until after the floor was damaged. The Seattle area dealer was supposed to have shipped it back to KC for repair but after it sat around for several weeks the dealer decided to repair it themselves. They remove all of the cabinetry as you have described, made a repair of unknown description to the floor and put everything back. Now there are several places where items no longer align with each other etc. If it were me I would insist that the trailer be shipped back to KC for repair on their nickel.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 03-22-2018, 07:20 PM   #6
Gainesville , Florida
Before everyone gets you upset call your dealer or the factory and see what they recommend..
Old 03-23-2018, 10:58 AM   #7
Astoria , Oregon
Thanks BAB. I have replaced floor in my previously owned 16ft Scamp. I used Aromatic Cedar just like they put in closets. Smelled realy good and looked much better than the stinky stained carpet. My concern with your plan to remove toilet and cut out bath area is the vinyl goes under shower base, toilet, and bed. The vinyl in my Airstream has a soft feel. If you push on it with fingers it leaves an empression that slowly goes away. I've been told it's not glued down, just flooting and held down by cabinets. Still working with local dealer for solution. Appreciate your comments. Steve
Old 03-23-2018, 11:42 AM   #8
2016 28' International
Perry , Georgia
I havenít read anything good on here about Airstream service departments in the northwest.
Vote 2 for the above.
J-K Georgia is offline   Reply With Quote
Old 03-23-2018, 11:51 AM   #9
dznf0g's Avatar
Oswego , Illinois
Hold the phone guys. The flooring shrinks in cold weather. Mine was worse this year more than ever, as it was very cold for very long in January and early February. I just went out and scooted and worked it back under the full length of the galley. I thought about removing drawers and stapling, but I don't think it smart, as it might shrink and tear next year. It's a small once a year, 5 minute fix.
-Rich-
Old 03-23-2018, 12:29 PM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
By the time I drove the brand new 2015 23D International Serenity from New Jersey to Paradise, TX (just under 2,000 miles) the dinette table leg had worn a hole in the stock flooring. I replaced that cheap stuff with Marmoleum as we had installed that in the Classic because of Airstream flooring failure.
Old 04-09-2018, 02:55 PM   #11
Wilmington , North Carolina
I would like to get an update on Steve Siler's situation for a couple of reasons: 1. How good is the AS customer service? and 2. I have a FC30 bunk (my 2nd AS) that has a couple of nicks in the vinyl thanks to my children. I am planning to change out the countertops with the help of a craftsman who works for me. While I am doing this I am considering pulling everything out and replacing the vinyl with flooring similar to the specialty AS models. Like others have mentioned, every time that I disassembled something, I find unacceptable imperfections that need attention/repair. Can anyone point me to a thread where someone has removed a late model interior for flooring replacement/upgrade? Sorry for hijacking the thread. Thanks!
tobyport is offline   Reply With Quote
Old 04-09-2018, 03:13 PM   #12
czunc's Avatar
2017 25' Flying Cloud
Dallas , Texas
We purchased our with a dimple in the flooring under the dinette. The selling dealer promised to repair the floor whenever we had a week or 2 to leave it. I was under the impression that they would steam the wrinkle out or let me know before replacing the linoleum but...... they cut the original floor out and glued a new floor in. The dealer thought they were doing a good job but there's nothing close to the original fit of the factory flooring. I was NOT happy about this at all but in the long run, we had planed on installing some type of hardwood looking flooring anyway. I think we will most likely use "Smartcore" from Lowes.
2017 25FB Flying Cloud
2017 Ford F-250 Platinum FX4
"Life is a team sport"
czunc is offline   Reply With Quote
Old 04-09-2018, 03:20 PM   #13
Smartcore looks like good stuff to consider. https://www.lowes.com/search?searchT...tcore+flooring I would really like to hear from some folks who have tackled the challenge of replacing the entire floor (i.e., full scale content removal/replacement so that ALL of the flooring could be replaced/factory original look). Thanks!
Old 04-10-2018, 08:33 AM   #14
Astoria , Oregon
I did arrange to have the bump repaired after the service advisor cleared the fix with Airstream headquarters. In a few days it was approved. I sechduled the repair then read all the comments on this forum and decided to live with it by putting a carpet over it. I figured if it gets worse I can always reschedule fix later. I'm still pretty sure the bump is more then just a wrinkle in the vinyl. And as I have said I have replaced flooring in previous owned trailers.
Had one light out and took in service then had two OKStream General Repair Forum 11 12-07-2017 10:20 AM
Anyone ever had a PERFECT outing with their Airstream? BessieB On The Road... 96 09-04-2017 08:39 AM
Anyone here wish they had NEW instead of OLD? THEPILL Our Community 75 01-30-2012 11:16 AM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 09:30 PM
Bathroom Epoxy. Anyone had 1st hand knowledge of these two refinishing products?? WILDRTEXAS Upholstery, Blinds, Walls & Interior Finishes 13 05-19-2010 07:56 PM
