Old 05-20-2013, 07:34 PM   #15
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
As already suggested, I too would be very concerned about increased "flexibility" of a composite sub-floor. The Airstream is already built to flex some as it encounters the bumps and grinds of road travel. But how much flexing can the frame, shell and all of the innards really take? I would be very concerned that over time, everything would start to loosen up and shake to pieces... just my 2 cents worth.
arktos55343 is offline   Reply With Quote
Old 05-26-2013, 06:29 PM   #16
blickcd's Avatar
Milford , Ohio
Some years ago I did a battery upgrade project and as part of that I replaced some rotted subfloor up front below the window with a marine composite called Seaboard. Also sold under the name Starboard.
Although I sealed some leaks up front as part of that project, knowing that area was prone to leaks I was thinking ahead. I just used a strip about 1' wide and 4' long. The stuff is pretty heavy but for a small piece like that I don't think the extra weight would be a problem. I wouldn't use it for the entire subfloor though, just because of the added weight.
See my blog under 'battery upgrade' for a few photos of the subfloor work.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 05-28-2013, 06:45 AM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What is your experience? How is it to work with and holding up?
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-31-2013, 06:47 AM   #18
blickcd's Avatar
Milford , Ohio
You can cut it and drill it with normal tools. Still looks as good as the day I put it in.
Christopher
Old 06-03-2013, 01:01 PM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kewl. I am collecting samples to pass around.
Channing
WBCCI# 30676
