Old 06-11-2014, 09:08 AM   #1
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
amateur frame repair????
HELP
My 1975 Airstream Sovereign has a serious broken frame, curb side
just back of the rear wheels. If has been reinforced in the past, looks
like boiler plate bolted on over the axles, then another steel piece with holes in it welded behind that. The crack runs down from the top nearly
to the bottom, but again this is reinforced with a "skid"
Finding a local welder to come over and fix it is not working.
Thought, could I get some 1ft 1/4 x 12" x 2 bars and bolt them
through with 1/2 8 rated bolts, say 4 per bar, and put 2 or 3 bars
across the break? I have no idea how to weld, wish I did, and at
78 I am at a loss.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 06-11-2014, 10:08 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Jim, can you tow the trailer to a welding shop?
Old 06-11-2014, 10:27 AM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
There has to be a welder out there that will come over and fix it, or let you take it to their shop if it still rolls. I had to ask around, but I found a welder to come repair the 7 or so breaks I found in my frame when I replaced the floor. Solid as a rock now.
Stephanie
Old 06-11-2014, 03:29 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't think you will be able to fix the frame with a bolt on solution. These trailers are weak right over the axles.
The best fix is going to be accomplished by removing the prior patches and welding in some structural support with the trailer jacked into the proper position.
Is the trailer immobile, or can it travel to a welding shop. There are mobile welders that will come on site, the trick is finding one.
Old 06-12-2014, 05:48 AM   #5
WBCCI 8562
1975 31' Sovereign
Hi Thanks to all for the response.
With a little work the trailer can be moved, the belly pan has been dropped to
get to the rear of the frame, a few rivets will hold it in place, also there has
been separation in the rear, I have it jacked back into place but have not fastened it, so this will drop out again when I move it. The frame over the axles was factory reinforced many years ago, too bad they did not got back further. I think the main cause was the type 27 battery mounted in the rear, we always made sure we did not travel with full holding tanks as it has suffered sag since I got it 10 years ago. Had it inspected by Uwe at
a restore rally and he thought it would be fine. Anyhow moved the battery to a vented airtight case up front. We just completed living full time in it
for 6 months while house hunting, I do not recommend that long a stint.
Old 06-12-2014, 05:55 AM   #6
Baltimore , Maryland
Can you post photos? I think a lot of what was described by the OP and the last poster was factory normal and not add ons by others.
Old 06-12-2014, 06:35 AM   #7
WBCCI 8562
1975 31' Sovereign
http://www.airforums.com/attachments...6/1/crack1.jpg
I really have no idea how to post photos, but his should be the link to the
crack photos
Old 06-12-2014, 07:46 AM   #8
crack photos
Photo shows lots of rust.
Basically, the crack is a fatigue crack, which is caused by lack of proper running gear balance.
Old 06-12-2014, 05:28 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
That is going to be a difficult fix to think through. It can be done by a welder who is a good thinker.
I think the repair might be best accomplished from the other side of the frame.
Jack the trailer into place plus a little extra lift in the back, and fishplate over the frame for several feet in each direction.
Of course i am speculating without seeing a picture of the other side of the frame.
Old 06-12-2014, 08:32 PM   #10
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
As an addendum, I don't think the repair itself will be that difficult, complicated, or expansive, it will just need to be well thought out and planned.
Old 06-13-2014, 11:21 AM   #11
WBCCI 8562
1975 31' Sovereign
Hi Andy We discussed balance when I bought new axles from you,
my Aluminum Wheels present a problem.
I had new radial tire put on for this last trip (3000 miles) when we moved
east. The dealer was supposed to have balanced the tires, on my old
set of bias ply I used the ceramic pellets to balance them and it seemed to work but we put the new tires on when one of the bias failed while traveling. Could have been the straw that broke the ol gals back.
I just want it fixed, getting camping-itis
Old 06-13-2014, 11:25 AM   #12
WBCCI 8562
1975 31' Sovereign
It bothers me, that this is/has been a long term problem with the rear bath
sovereign, why them isn't more information available, other then those that do a shell off rebuild.??????I mean that would be great if one could afford it and had the shop to do it.
Old 06-13-2014, 11:28 AM   #13
What is the flat spot dimension on the backside of your mag wheels?
Old 06-13-2014, 11:41 AM   #14
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Ok, not exactly your situation, but it should give you some ideas.
When I put the axles under my trailer I raised the trailer three inches, and I worked with a bit of sag at the same time.
Name:	ImageUploadedByAirstream Forums1402681024.326398.jpg
ID:	214145Click image for larger version
Name:	ImageUploadedByAirstream Forums1402681043.419939.jpg
ID:	214146Click image for larger version
Name:	ImageUploadedByAirstream Forums1402681090.225041.jpg
My idea for your trailer would be to jack up the rear and fishplate a piece of 1"x 2" angle over a long section of the frame behind the wheels, simple, easy, and done.
I would probably run something across the bottom at the same time.
Amateur Radio MoHo jking Classic Motorhomes 3 05-13-2007 08:48 PM
Frame Repair or New Frame muddy_hollow Brakes & Brake Controllers 14 09-26-2006 05:55 PM
Amateur Radio Club junbe WBCCI Forum 7 03-16-2005 03:03 AM
amateur radio connection white1949 General Motorhome Topics 24 08-31-2004 09:13 AM
amateur radio antenna for motorhome white1949 Our Community 0 01-01-2003 10:17 AM
