On the forum here, I've seen that many people have used laminate, cork or hardware flooring in their trailers or motor homes. I found some cork engineered wood flooring ( cork on top and bottom, wood in middle) click type flooring at Home Depot.
Millstead Natural Plank Cork 13/32 in. Thick x 5-1/2 in. Wide x 36 in. Length Cork Flooring (10.92 sq. ft. / case)-PF9578 at The Home Depot
I've talked to 2 of the people in the flooring dept. there and the keep trying to steer me to the Traffic Master Allure flooring telling me that this is the type of flooring that's best for RVs and that the laminates and wood will be a problem due to movement. They have me worried. Will the flooring I picked out be a problem? The van has a metal floor with some foam ( like the blue stuff you use with Pergo but thicker) and I was going to have it installed on top of this. ( I'm not doing the install, someone else is) there's carpet there now but I don't want carpet.
I'd appreciate any thoughts and opinions
Karen
