Old 07-23-2017, 02:14 AM   #1
Loganville , Georgia
Am I correct in that airstream fixed this design flaw with the bumper, frame, and she
Hey guys and gals. So many different forums I could put this under, figured I'd start here!
Is it reasonable for someone looking to buy used to rule out the 2011 and older models due to the dreaded bumper/frame water intrusion in the rear?
Do we have any information from airstream stating that they specifically fixed the terrible bumper/ frame/ shell design flaw that plagued many of their older model trailers?
Thanks!
gsugtdodge is offline   Reply With Quote
Old 07-23-2017, 04:59 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
An early morning free bump 'cuz I'd like to know
majorairhead is offline   Reply With Quote
Old 07-23-2017, 05:34 AM   #3
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
The Aluminum floor channel has wrapped around the floor since the early 1980's. for water to soak into the floor from the bumper lid it would have to run uphill. Most rear floor damage is due to a leak further up on the shell collecting in the top portion of the floor channel and seeping onto the floor.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 07-23-2017, 05:42 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I've read others state 2012 and above have the fix. Most of the my readings of this problem have been from pre-2012 owners of Safaris. I have a 2008 Classic 25fb and have no bumper water infiltration. I have yet to read of a report from a Classic user to have that issue not that there couldn't be owners that have had a subfloor issue. The bumper design is different on the Classic and that helps keep water out.
When I had my interior remodel performed last fall I had the vinyl floor replaced with Marmoleum. The company that did the work (A&P Vintage Trailer Works) reported my floor was sound and no prior leaking evidence. Now you can get water leaks from above via windows that can run down to the floor and get under the vinyl where the edges separate from the floor/shell floor area and if unchecked can simulate a leaking bumper scenario.
Kelvin
Old 07-23-2017, 06:24 AM   #5
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
From my reading on this forum about leaks, I became paranoid about my AS. So much that I tore into the rear bumper area, ran probe tests and then sliced open the vinyl floor to inspect the floor. I found a good seal in the back and no signs of leakage. There was a minor stain in the bath area near the wall where most likely it was from the time I accidentally left the shower on lock versus shutting it off and it leaked onto the floor while I was there. No rot.
Most every post I read about floor rot was most often related to panoramic windows. I was told the bumper area too and several posts mention it. I do not think that leaking is necessarily related to a specific year or a cutoff. It is true that in 2012-2013, according to the Airstream rep who spoke at a rally in Sarasota, that they started adding washer seals to rivets. Since then; however, there have been posters with newer trailers that leaked too. I believe that owners have to be observant as much as possible.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-23-2017, 06:31 AM   #6
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just remember, you can have the worst rated used car in the world to own; maintain it well, and it can be the best car you've owned, (mine is a 95 Jaguar XJS convertible). Conversly you can buy the best recommended used car, but poorly maintained and it will be a dog.
The newest trailers also come with their fair share of horror stories.
So don't discount older trailers, as a well maintained, sheltered trailer that has possibly been re-seamed and inspected regularly will be a very good buy.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-23-2017, 12:37 PM   #7
Thanks guys, hey mods, anyway we can move this post to the repairs section of the forums without reposting it again ? Probably more appropriate over there.
Old 07-23-2017, 12:43 PM   #8
Unfortunately the classic is too big for me.
I'm looking at the 23 or 25 foot flying clouds and I'm just kinda wondering if I should expand my search to include older models from maybe 2008-2011. so far I've only been looking at 2012+ because I thought that's when the design issue was fixed/addressed but looks like there are no clear answers on the topic.
Old 07-23-2017, 12:59 PM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I had a 2001 Safari 25 for two years. The only time the floor got wet was when I left the rear storage door open during a downpour. I read about the problem but a moisture meter probe of my unit showed no indication of moisture intrusion until I had my senior moment.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-26-2017, 08:22 PM   #10
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg & Cambridge , Mississippi / New York
Following. I just finished driving my 2014 27FB Classic from Mississippi to New York and noticed that stains have appeared under the linoleum on both sides of the dinette cabinets along the back bulkhead. Obviously there is water leaking into the subflooring, but I cannot tell where it is coming from...
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 07-26-2017, 10:06 PM   #11
do you have photos?
Old 07-27-2017, 10:20 PM   #12
Adiredneck's Avatar
2014 27' FB Classic
gsugtdodge,
No, no camera on this trip yet - should probably buy a small digital...
Tim
Roadstar Omni-Directional TV Antenna Airstream Location Design Flaw beachbouy Audio, Video & TV 0 09-07-2016 11:25 AM
Honda 2000i Design Flaw? Ken Lynch Generators & Solar Power 0 08-09-2010 09:12 PM
Can she be fixed? Pinhead Exterior Restoration Forum 10 12-01-2005 10:25 PM
Design Flaw Rust DreamStream 2005 and newer - Bambi all models 5 11-02-2005 03:06 PM
She's no Zip Dee - but she'll do..... 05ModPod Awnings 3 05-12-2004 03:43 PM
