I'm attempting to fix a rear end sag, separation, on my '67 Safari and have read every imaginable thing I can find. Andy, at Inland, has extensive commentary on the proper fix and I'm trying to follow that advise. There are NO broken or cracked floor channels, just bigger holes where bolts were pulled through the channel. (PO had an 85 lb piece of 4" angle iron and a welded on trailer hitch, bolted to the rear bumper. Who knows what he pulled or how far) I'm going to put 1/4 inch steel in the bottom of the channel, as advised, but I keep reading about the deleterious effects of combining steel with aluminum. I came across a thread once, and I want to attribute it to Andy (Inland), but now I can't find it, that said this advise was mostly bunk and that there were plenty of places on AS's where differing metals meet up. Also, can I use angle iron in that channel, cut, bent, and welded into a single piece to follow the butt end and the curve? I'm thinking I can rivet the exterior skin back through that angle iron and aluminum channel. Angle iron's stiffer than flat steel. Yes, I know I'll need to address the axle, balance issues, but I need to get this rear end thing done before it gets too cold. I'll worry about the other stuff later. Andy, if I've attributed something to you that you didn't say, please let me know. Sorry in advance!
