Old 07-29-2016, 10:23 PM   #1
trois-rivières , Quebec
aluminium frame, utopia?
I talked with my dad than we will probably need to re build the frame on our futur AS.
So my dad came with the idea to re build the new frame in aluminium like those industries did with those pick up (like the new F150 ford I think).
So the question : Is it possible to build a new AS frame in aluminium.
I know it will not be the same cost.
boubou is offline   Reply With Quote
Old 07-29-2016, 11:24 PM   #2
1979 23' Safari
Wayland , New York
Can be done, and has been done. I remember someone had a boat trailer shop custom build one out of aluminum. Requires more aluminum to make up for the lower strength. Also, aluminum is more susceptible to fatigue failure than steel. Welding the aluminum is also more labor intensive. Aluminum is also more expensive.
You'd probably be better off with a well designed and slightly reinforced/strengthened steel frame that is powder coated or just well coated. You could make one a little taller to fit some bigger tanks and a stiffer back end to be able to put on a bike rack if desired.
Old 07-30-2016, 12:01 AM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Ford built the body of the new F-150 out of aluminum, not the frame. Aluminum frames have been discussed on this forum, but they could have problems as mentioned in the above post. Also the coupler, axles and other items would still be made out of steel and have to be bolted in place instead of welded. One forum member made a complete frame for his Argosy out of stainless steel.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-30-2016, 12:15 AM   #4
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Check it out
http://www.vinstream.com/ALUMINUM-CHASSIS.html
Love the idea.
Al Boondy is offline   Reply With Quote
Old 07-30-2016, 02:36 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
IMHO, while a good aluminum frame can be built, I don't see the extra cost and trouble being worth it.
Steel is SO easy to work with, aluminum will require a lot more work, and a lot more engineering.
Gradiens super tenui glacie.
Old 07-30-2016, 07:29 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Our last SOB trailer had a galvanised steel frame which held up extremely well - even to being washed with winter road salt.
Unfortunately the rest of the trailer didn't hold up as well! We eventually got rid of it due to high cost of repairing damage to the flooring and laminated sidewalls due to recurring water leaks - but the frame looked just like new!
I wish our AS had been designed with a composite floor, a galvanised frame - and no enclosed belly pan!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Aluminium Grades 71airON Cleaning, Stripping & Polishing 8 07-15-2017 03:37 PM
Does 1967 have Aluminium Frame Floor ? timhortons Repairing/Replacing Floor &/or Frame 7 10-13-2015 06:48 PM
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 5 09-08-2014 09:11 AM
WTB: '83 Excella HUBCAP 15" Aluminium 6 Beach rats 1981 - 1983 Excella 0 02-02-2009 05:25 PM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
