Old 09-04-2010, 10:43 AM   #1
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Alluminum panel below sub floor
Upon removal of forward sub floor I found this large section of alluminum. It was not fastened to skin in any way, but held in place with floor fasteners. there is corrosion at the bolts.Does any know its purpose? Attached to the underside is a 25 amp breaker in the wiring harness. Is this meant to act as a disaster fuse? It seems an odd location, as it is not accessible.
ID:	110026   Click image for larger version
ID:	110028   Click image for larger version
JLGT5107 is offline   Reply With Quote
Old 09-04-2010, 11:49 AM   #2
x
XXXX , XXXX
Judging from the location the aluminum plate you discovered looks like the upper cover for the spare tire carrier. If a spare carrier was installed the belly pan would be removed between the main frame rails from the first crossmember to the front C Channel. That area would then be exposed to the elements and this plate would protect the floor. Is that breaker installed in the wiring harness that goes to the tow vehicle? The breaker looks like one of those automatic resetting breakers. It would act like a surge protector between the tow vehicle and the trailer.
wasagachris is offline   Reply With Quote
Honeycomb Aluminum Panel As Sub Floor, the adventure... Rivka Repairing/Replacing Floor &/or Frame 37 12-25-2015 03:25 PM
used panel bimpy Ribs, Skins & Rivets 4 11-15-2009 10:41 AM
Monitor Panel Darrell Root General Interior Topics 4 05-14-2007 07:15 PM
Panel or not Over59 Ribs, Skins & Rivets 6 10-07-2004 12:20 PM
