Old 07-13-2014, 09:56 PM   #1
1962 22' Safari
Corpus Christi , Texas
All stripped out, now what?
Ok internet helpers here is where we stand. The inside is all clear on the 64 Safari. We kept some salvageable pieces for templates, however most of the wood was shot beyond redemption. We pulled the floor up on what we believe is the worst section. We knew the cross members were completely gone in the rear. The question that we are looking for help on is this. Given the pictures of the frame, the outside shell is ok but will need some work, and that The AS was given to us for free, what are we looking at to make this thing usable and nice again? My wife is a little concerned that we might be better off giving up on this one, that we will be behind on it very quick. Would love to get a set of eyes on it from someone local and knowledgable. We are in Corpus Christi, TX
Name:	ImageUploadedByAirstream Forums1405309892.891080.jpg
ID:	216330Click image for larger version
Name:	ImageUploadedByAirstream Forums1405309951.222744.jpg
ID:	216331Click image for larger version
Name:	ImageUploadedByAirstream Forums1405309980.075675.jpg
ID:	216332Click image for larger version
Name:	ImageUploadedByAirstream Forums1405310025.800293.jpg
ID:	216333Click image for larger version
Name:	ImageUploadedByAirstream Forums1405310046.701888.jpg
ID:	216334Click image for larger version
Name:	ImageUploadedByAirstream Forums1405310078.862250.jpg
RevandDoc is offline   Reply With Quote
Old 07-14-2014, 08:46 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Rev,
All things are fixable. It just takes time and money. The issues that you have with your frame are typical and fairly easy to fix. Some new cross-members, a new pice of frame and you are ready to put in a new floor.
There are some members in CC that you might contact by PM. Slowmover is one that immediately comes to mind.
There are are also several threads on here dealing with these issues. Use the Search tab at the top and type your request in the google search box. You can also go to the top of the page under the Air Forums sign and click on Forums and go to "Floor and Frame".
Hope this helps.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-14-2014, 08:56 AM   #3
lonewolf1977's Avatar
1957 26' Overlander
Winston Salem , North Carolina
Definitely start checking out the floor/frame threads. Lots of valuable info there. In the meantime, find someone that can weld some new crossmembers in that will give you some structural integrity. Start sanding the parts that are strong. Order some POR-15. That way when you get your new frame member in, you can prep & paint it to prevent future rust. Our rear floor was not salvageable either. The measuring and fitting those curves are not fun, but you can do it.
Airstreamin' dreamin'.
Follow our blog! http://theoverlanderproject.blogspot.com/
lonewolf1977 is offline   Reply With Quote
Old 07-14-2014, 08:59 AM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
poke around to see which i surface rust and which pieces are shot. Plan to replace those that are shot. Do it right the first time, it will be rewarding later.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-14-2014, 09:23 AM   #5
1981 31' Excella II
New Market , Alabama
It does not look that bad as far as the frame. POR15 paint and replace anything else that is rusted out.
Perry
Old 07-14-2014, 07:15 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
First lesson is that sometimes the "free" trailer is one of the more expensive ones!
It all depends on what you mean by "useable and nice," but I would say that if you are willing to do all the work yourselves, it could be accomplished with $4-5000 depending on how many major appliances you need to replace.
When you say that you fear you will be behind on it very quickly, I wonder what you are comparing to. If you compare to a trailer that has been restored to newish condition by a professional or to a new trailer, then you could spend $30k or more before you are behind. If you are comparing to trailers you see on Craigslist that are advertised as being in "good condition," for $3500, I wouldn't bother--those trailers have all the same problems yours does, they just haven't been exposed yet.
Ultimately, the question is what is your budget for the project? If you thought that you could take a 50 year old trailer that you got for free and be camping in a nice and useable trailer in a few weeks' time after sprucing it up a bit, then your expectations are being recalibrated already.
good luck!
Do all years need to be stripped prior to polish? Redrock YEG Cleaning, Stripping & Polishing 6 05-25-2014 12:03 PM
1971 airstream travel trailer 23 ft stripped out shell eBay Watch Airstreams on eBay 0 02-06-2010 12:40 PM
argosy stripped to bare aluminum alumibum Cleaning, Stripping & Polishing 10 03-04-2007 08:17 PM
can a 92 limited classic be stripped and polished? 0557 Cleaning, Stripping & Polishing 6 02-23-2004 09:14 AM
