Old 01-14-2013, 02:50 PM   #1
KristinS's Avatar
Full-Timing , All states!
Advice Needed: Sealing '65 Hollow A-Frame Ends
We just finished painting the frame of our '65 Overlander in preparation for a new subfloor, and as I was painting I noticed that water has been getting into our trailer through the open ends of the a-frame under the coupler. The beams are hollow and open to the elements where they meet under the coupler (our trailer wiring ran through one of them).
I'm guessing that while towing in the rain or just parked in wet weather as ours has been, water can get inside of them and flow into the belly of the trailer. This seems like a huge design flaw, and could undermine all our hard work to keep water, rodents and insects out of there.
The question is, can we seal these ends up somehow, and do we seal just the outside ends at the coupler, or both ends? Does the interior of the beam need to breathe, or will that plus any moisture trapped in the belly promote more rust?
What's the best way to seal it? We didn't want to take the coupler off but we can if we have to weld. Would spray foam work well enough if we reapplied it periodically?
I know that Colin and others who have the space and equipment typically pour rust inhibitor into the hollow a-frames and rotisserie the frame so the inside is well coated. We couldn't do this since we were limited to a shell-on restoration. I painted as far into each end as I could reach, but will just have to hope that not letting more water in will halt any futher rust. We want the trailer to last us 10+ years of full-timing, so we're trying to do everything right the first time.
Thanks in advance for any help! We've been doing well so far with finding help here, but some things like this are way out of our area of expertise!
KristinS is offline   Reply With Quote
Old 01-14-2013, 05:23 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Rather than sealing the frame, wouldn't it be better to drill small drain holes instead, so the water can run out before it gets to your trailer's belly pan?
Drill the drain holes close to where the frame meets the trailer skin, so the frame drains when tilted up (through the drain holes) or tilted down (through the open front end of the frame). Then, when the trailer is in storage, instead of completely leveling it, store it with the front end tilted slightly down, just enough to ensure that any water that gets into the frame drains away from the trailer's belly pan, not toward it.
If you're worried about weakening the frame where you drill the drain holes, you can weld thick washers to the bottom of the frame where you intend to drill (fillet weld, all around, inside and outside the washer) as a doubler plate, then drill through the hole in the washer.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-14-2013, 05:44 PM   #3
KristinS's Avatar
That's an idea, thanks for the suggestion. I guess I'm as worried about water getting in the a-frame at all as I am about it making it to the belly pan, though? If we keep letting it in there and can't paint the steel to resist rust, won't it keep rusting, even with somewhere to drain?
Maybe we could put some chassis paint on a wadded up rag wrapped around a paint stirrer or something and try to get a coating on at least part of it, but it'll never be as good as really coating the inside.
We're full-timing in our trailer someday, so it'll never be covered or in storage. I just worry about that constant exposure to the elements, bugs and rodents.
Not saying it's not what we'll have to do, but I don't want to drill holes and seal up my trailer belly without exploring all my options first!
Kristin
Previously owned a 1965 Overlander, fully renovated it, then sold it after a year of full-time travel. We're taking a break from trailers to try a class A for a while, but we're still Airstreamers at heart!
Our blog | Video tour of our trailer
Old 01-14-2013, 05:53 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
This is what Colin did to cap mine...post 91
http://www.airforums.com/forums/f109...-78136-10.html
reinergirl is offline   Reply With Quote
Old 01-14-2013, 06:03 PM   #5
KristinS's Avatar
Thanks, reinergirl! I thought about calling him and asking but I feel bad harassing him too much and only being able to buy a couple axles in return. I sure wish we lived closer to him and could have him do it!
I wonder if metal caps could just be put on with Vulkem instead of welding. We don't have welding skills or equipment and I really didn't want to have to remove our coupler just to seal those up. We'd have to re-seal them periodically, but it sure would save us a lot of time and money. Hmm.
Kristin
Old 01-14-2013, 08:45 PM   #6
Seymour1971's Avatar
1971 21' Globetrotter
Western US Cities , CA,AZ,NV,UT,OR,WA
Have you considered expanding foam. This is what I used. Working well at keeping water and pests out.
Seymour1971 is offline   Reply With Quote
Old 01-14-2013, 09:30 PM   #7
KristinS's Avatar
Seymour - We did consider that, actually. I was wondering how well it would hold up and I'm glad to hear you had success. What type did you use, just the stuff in a can from the hardware stores?
Old 01-14-2013, 10:35 PM   #8
1976 Argosy 26
Fair Oaks , California
I am in the process of my Argosy renovation and was also concerned about rust inside the frame channel. I drilled a 3/16 hole at the end of the frame to let out any water. After allowing it to dry after flushing out the voids, I applied this Eastwood product. Seemed to be the only solution available. Hope this helps.
http://www.eastwood.com/internal-fra...ay-nozzle.html
Argosy Heir is offline   Reply With Quote
Old 01-14-2013, 11:58 PM   #9
alumascoupe's Avatar
1966 26' Overlander
Frozen , Tundra
I had a carpenter Ant infestation (they were doing a great job of removing wet/rotten wood ! ) I sprayed all my tires with insecticide and found they were climbing the Jack then using the open ends of the frame as a Super Highway into the belly pan and subsequently the whole trailer, plug those holes even if you do drill some drain holes, I also found a completely mummified chipmunk (minus the linen strips of course !) that I'm fairly sure entered the trailer through the frame holes. Depending where you live, all kinds of stuff can get in there.
alumascoupe is offline   Reply With Quote
Old 01-15-2013, 07:35 AM   #10
KristinS's Avatar
Thanks, Argosy Heir! That's exactly what I was looking for since I couldn't get paint inside there. I think we'll end up sealing the frame with spray foam or metal caps, but I'd like to apply something like that to try to encapsulate the rust first.
Alumascoupe - Thanks for the tip! When we opened our belly we found a ton of infestations as well. I recently worked for a pest control chemicals company, and we carried a stainless steel mesh with very tiny holes that's used in foundations of homes to prevent termites from entering around floor penetrations. It's called TermiMesh. We're going to use it over as many holes in the frame and belly as we can. It should give us a lot more protection than the sad excuse for a pest screen that was over our refrigerator floor vent before--you could fit your pinkie finger in the gaps!
We're also going to treat our subfloor with a liquid product called PenaShield before installing it. It's a borate-based, natural wood preservative, fungicide and insecticide. It kills and prevents termites and carpenter ants and offers years of residual protection. It may be overkill, but if we're going to be living in this trailer for a long time I want to take every precaution we can!
Old 01-15-2013, 08:10 AM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Just a suggestion from a different direction. In the automobile restoration world they use spray products for rust prevention. There is a catalogue company named Eastwood that will carry all these products. Look for one with a long extension wand that you can reach down into those exposed frame members and give a good spray. Water will get down into these voids, you can bet on that, but letting the air flow freely will also dry them out. I would not advise trying to seal them up and block the air flow. Prevent the corrosion and let it evaporate.
PS: If you have carpenter ants you have other issues, specifically leaks. Correct the issues then evict the ants.
Good luck whichever route you choose.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-15-2013, 08:24 AM   #12
KristinS's Avatar
Thanks, Roger! That's a great solution, I'm going to pick some up and try it.
Ordinarily I wouldn't seal the ends either, but unlike a car frame that's separated from the interior, these hollow beams start under the coupler and terminate inside the belly of the trailer, directly under the floor. I'm worried that water draining under the plywood subfloor will rot it from underneath, and that it will also be a great entry point for insects and rodents to spread into our bellypan and make their way into the trailer through plumbing openings and such. I could seal just the end of it in the belly, but then I still worry about bugs and rodents nesting in the beams and causing us issues when we hitch up. I don't really want to deal with a nest of stinging insects deep in our trailer tongue!
Old 01-18-2013, 07:53 AM   #13
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I have been kicking around the same idea. I think I will be making caps out of aluminan flashing, and then riteving them over the ends with SS rivets. Adding in Spray Foam would be a good idea.
Silverflames is offline   Reply With Quote
Old 01-18-2013, 10:37 AM   #14
retired USA/USAF
2001 30' Excella
I'm having difficulty picturing this. I thought that the frame rails ran front to rear. I didn't think that they would dead end in an opening into the belly pan. Now that you mention this and I think about it, yes I guess they could / should be sealed. But I still go with the thought of spraying some moisture inhibitor down there first. We all know that moisture will get in there. Either directly or by condensation so putting a layer of something could only help. In a perfect world there's all sorts of stuff that could / should have been done during fabrication that would work nicely. Butttttt....... . Now we need to work with what we got. Someday I would like to open up the belly of ours and see what's down there. Sooner would be best since I know it's had an easy life with indoor storage until now. Maybe one of these days I will take on that project. But not right now.
Good luck with whichever route you take with yours.
Roger in NJ
TAC - NJ 18
