04-04-2011, 06:57 AM
#141
Newton
Originally Posted by Top
No, no road trip today. Hung out around here and worked on Abby some. Did some shopping. I went out with my daughter and helped her pick out a guitar. She has been saving her money that I pay her for getting all "A"s in school. She won the district championship for the one mile run yesterday with a time of 6:00. We just finished eating the steaks I grilled. Lovely day here in Texas.
Congrats to your daughter. Y'all are just a family full of talents. Athletes, cooks, guitarists, and Airstream builder.
Your floor is looking good. I like the color I'm now very curious to see it all laid down. Keep up the good work.
04-04-2011, 07:33 AM
#142
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Thanks Mr. S. Very kind of you. I just have to finish up the plumbing and then I'll get the other two sheets installed. I also need more elevator bolts. I'm excited to see how it will look too. The color is Sherwin Williams MWB-09 Cinnamon. It is the closest color I could find to match the original orange shag carpet.
Lance
04-04-2011, 07:12 PM
#143
Always learning
1972 29' Ambassador
Central
Drain plumbing
Lance
04-04-2011, 07:16 PM
#144
Florissant
, USA
Nice work...bet you had a better time than I did today. I'm back in cold Missouri.
Steve
04-04-2011, 07:20 PM
#145
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Steve
Looking good Top. You are definately getting to the end.
Steve,
I'm in cold Oklahoma
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
04-04-2011, 10:31 PM
#146
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
Wow, what a great layout with the tanks. Worked out awesome!!! I hope I can get mine to work out as awesome.
04-05-2011, 05:14 AM
#147
Always learning
1972 29' Ambassador
Central
Steve,
Thank you. Enjoy the cool weather. Come July, you'll be missing it!
Bruce,
Thanks! The end is a looooooong ways away yet. But, I'm moving toward it.
Ed,
Thanks. I never had any doubt it would work out . After all, it is the first time I've ever did any plumbing! Yeah right! I was so relieved
yesterday when it all went together as I had envisioned. Two months ago when I was lying under Abby with a pencil, measuring tape and some paper, my wife just figured I was taking a nap or something! I probably won't put the belly pan back up until after we've made several trips to be sure everything will work out nicely.
Lance
04-05-2011, 09:37 AM
#148
1968 26' Overlander
West Richland
That's awsome! You made it look easy. Now when I try it I'll have some courage to go on... Thanks for documenting!!
04-10-2011, 08:29 PM
#149
Always learning
1972 29' Ambassador
Central
Sheet metal repair
Yesterday we went to the bluebonnet festival in Burnet. We had a nice little family day. There was an air show and a car show so it was cool. Actually it was hot as hell. We had some good fest food. I'm not too sure about these Lutherans though.
Today I got a full day of work on Abby. I decided it was time to stop dragging my feet with the sheet metal repairs under the rear access hatch. I have been an aircraft mechanic for almost 22 years now. A lot of that time I have spent supervising. Supervising is a lot easier! I was not formally trained as an airframe/structural mechanic. I am a power plant mechanic. Sheet metal/structure repairers have always been in the same section where I've worked, so I have dabbled in sheet metal repairs before. I just don't have a whole lot of experience at it yet. Seeing some of the poor sheet metal craftsmanship from the factory, I'm not at all afraid to give it my best. As you can see from this picture, there is no saving the skin here. It is too far gone from the dissimilar metal corrosion.
So I drilled out 3/4 of the rivets holding this piece of skin in and cut it just below the top of the rivet line for the hatch. I laid it on some new 2024 T3 clad and cut out a new piece. I used my tin snips for the fine work, then used my jig saw to make the long cut.
I have most of the holes drilled. Just need to drill new holes that go through the rear hold down plate and into the C channel. Speaking of the C channel, I spent a few hours today cleaning corrosion from the C channel with a scotch brite pad and a scotch brite disk.
I have ordered some supplies from Skygeek.com to rectify the corrosion problem with the C channel. It should be here tomorrow. When I look at where the assemblers drilled holes sometimes, I just have to chuckle.
After I finished prepping the C channel, I cut the holes in the next section of floor for the gray tank inlets. I also had to cut it to fit between the wheel wells. I then coated the fresh cuts with epoxy. I'm shooting to have the floor completely installed by next Sunday. We'll see how that goes with that four letter word that starts with "W" and ends with "ORK"!
Lance
04-10-2011, 08:44 PM
#150
x
XXXX
, XXXX
Hey Lance did you cut your patches a little bit long on the upright section so that you can tuck it under the existing panel. That way water will flow over the joint and not under and behind it.
04-10-2011, 08:51 PM
#151
Always learning
1972 29' Ambassador
Central
Sure did.
Lance
04-10-2011, 08:58 PM
#152
x
XXXX
, XXXX
I really knew you would have. You didn't mention it and when others read how to do the work as many are reading your thread and learning they will know as well.
You going to fill us in on the mystery supplies to fix the corrosion problem? I'm intrigued.
04-10-2011, 09:07 PM
#153
Always learning
1972 29' Ambassador
Central
Well, I guess I should let y'all know what I'm using. It is just basic corrosion control stuff we use in aircraft maintenance all the time.
Turco 594416 Alumiprep 33
Henkel 594419 Alodine 1201
Orr-lac 343 Yellow Zinc Chromate Primer
Tempo A151 Medium Gray Epoxy Propeller Coating
I have to do more "mechanical" corrosion removal before all the chemicals get thrown at it. It should be looking good when I'm done. There will be no steel to aluminum contact without some sort of barrier.
Lance
04-11-2011, 01:56 PM
#154
2020 30' Classic
Derwood
, Maryland
Hey Top,
Just stumpled across your postings and started from the 1st page - great stuff!
BTW - what are you gonna do with the other "Top's" that are here - you know we have lots of military guys floating on our forums
Keep up the great work (inlcluding posts and pics)!
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
04-11-2011, 02:39 PM
#155
Always learning
1972 29' Ambassador
Central
Thanks JFsheck. I'll probably have rank pulled on me at some point. But, hey it wouldn't be the first time! Lol
Prosit!
Lance
04-11-2011, 04:18 PM
#156
Always learning
1972 29' Ambassador
Central
The FEDEX guy delivered my chemicals from Skygeek to a lady down the street. She was nice enough to deliver them.
I also took the new rear hold down plate to the hangar today and bent it on the brake. It is .063 stainless steel.
Lance
04-11-2011, 06:36 PM
#157
Always learning
1972 29' Ambassador
Central
Well I got to use the Alumiprep 33 before dinner. I used it full strength. Cleaned up the C channel pretty good. Here are some pics.
Lance
04-11-2011, 06:42 PM
#158
Always learning
1972 29' Ambassador
Central
After dinner I worked on the patch for under the rear hatch door. First I etched it with the Alumiprep 33. Then I put on a heavy dose of alodine 1201. Next was the zinc chromate primer and then the final coat is the gray prop epoxy.
Lance
04-11-2011, 07:10 PM
#159
1981 20' International
Shasta Lake City
Nice work...Trainer of Personnel
04-11-2011, 10:40 PM
#160
Tool Hoarder
West
Nice work1 I got the same tanks for my rig. Im trying to figure out I want to build a box for them to sit in. I bought 16 ga steel formed channel to hang them with. Hope to have it figured out soon. Want to get it put back togeather!!
