Old 06-08-2012, 07:07 AM   #421
1981 31' Excella II
New Market , Alabama
I guess the availability of the different manufactures of insulation is regional. The RMAX is available here in 1/2 sheets only. I have never seen the 1" stuff. I am finding that most of the stuff they sell is for going under siding on a house. Finding thicker stuff can be a challenge. I thought about no insulation at all but decided to put a couple 1/2 layers in the side wrap areas that are not going to be easy to access later. I don't have any insulation between the frame members right now but it will be easy to add some later since the skins now bolt on. I like the foam with the aluminum radiation barrier like the stuff you used and the RMAX. It is like a combination of the foam R value and the heat reflecting qualities of the shinney bubble wrap stuff.
Good Job on all your rebuild work TOP. The good thing about doing all this stuff yourself is you know how to seal leaks and where they pop up. You also know how to fix what breaks.
Perry
Old 06-08-2012, 06:32 PM   #422
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Fairing
Working on floor fairing. Here are a few in-progress pics.
Lance
Top is offline   Reply With Quote
Old 06-12-2012, 07:15 PM   #423
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Ring-ring-ring-ring-Banana phone!
The banana wraps on Abby were very dented and beat up. It really used to bother me how ugly they were.
ID:	160841Click image for larger version
After hours and hours of bumping, grinding, sanding the finished product turned out pretty good. It would be nice to have an English wheel sometimes. Although they are not perfect, I'm very happy with the results.
ID:	160843Click image for larger version
ID:	160844Click image for larger version
Lance
Old 06-12-2012, 07:20 PM   #424
Baltimore , Maryland
Lance, I found two things work real well on those; a sand/ shot bag and a mallet and/ or handing it off to my employee Wayne
Old 06-12-2012, 07:38 PM   #425
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Out of Waynes (World)
Thanks for the tip, Frank. Unfortunately, I'm all out of Waynes here in Nolanville. I'm getting better with these hammers. I would like a nice shot bag. Maybe for Father's day?
Lance
Old 06-12-2012, 08:48 PM   #426
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
For Chuck's polyiso pleasure
After I got the banana wraps and rub-rail trim on I sealed up the rivets from the inside. The only things left unsealed in the front U channel are the drain holes around the perimeter. Now for insulating.
Here is what the stinky, filthy, nasty, itchy fiberglass looked like before I threw it in the trash.
And here is a nice clean installation of 1" Dow TUFF-R polyiso insulation. All seams are taped with 3M aluminum foil tape. The insulation is flush with the inside of the ribs. That provides an airspace between the exterior skin and the insulation.
Lance
Old 06-12-2012, 09:27 PM   #427
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The improvement in the banana wraps is pretty drastic! I wonder how they got that bad in the first place... someone towing on gravel with a dually with no mud flaps?
David
Old 06-12-2012, 09:37 PM   #428
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks!
I'm not positive, but it seems to me that Abby has been to Alaska and back three or four times! The old Air Force Colonel and his wife must have had some awesome travels in Abby. I wish they had kept a travel log. That would be something cool to have for sure.
Lance
Old 06-13-2012, 08:58 AM   #429
Medford , Oregon
Attachment 160401
Attachment 160400
Attachment 160402
On this floor fairing (what does that mean, "fairing"?): If I have, which I do, gaps in the plywood sections for my rear floor replacement, is there something like a "backer rod" you could suggest before applying the "fairing"?? Like a flexible rope to squeeze in between before apply that floor stuff?? some of my gaps are too big I feel to apply the leveling stuff.
Really nice job on the banana skins and insulation by the way. In fact the whole job will stand up for quite a while for all of us jumping in to the same
boat ;-)
Richard & Della
Della is offline   Reply With Quote
Old 06-13-2012, 12:52 PM   #430
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Fair to the eye="Fairing" also known as "leveling"
boat ;-)
Richard & Della
Thanks very much.
I don't know how deep or wide your gaps are, but if you mix the fairing compound and epoxy to a thick peanut butter consistency, it won't run or sag. All of your seams should be over a crossmember/outrigger or have a cleat under it so, I don't think a backer or plug would be necessary. Just closely follow the directions in the West System user manual.
Lance
Old 06-13-2012, 08:16 PM   #431
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Tic Toc, Tic Toc...
I should have been done a week ago, but I'm not. We have been making progress. I say we because my oldest son, Scotty, has been helping me out. It is great to have a second pair of hands.
Before the insulation went in, I sealed all of the rivets from the inside with TremPro/VULKEM 626.
ID:	160949Click image for larger version
ID:	160950Click image for larger version
I don't want any water getting in.
This morning I finished the insulation in the walls. It is a bit tedious, but a few hours of work is a great trade to have high quality insulation that will not hold water. We left a small note for whomever is around to take her apart again. Hopefully it won't be me.
ID:	160952Click image for larger version
Next was to make a template out of builder's paper.
ID:	160954Click image for larger version
Tomorrow I'll cut it out and roll it up and put it in Abby through the front window. Then it will be time to lay the glue and roll it.
Lance
Old 06-13-2012, 09:00 PM   #432
Central , Mississippi
Awesum looking work Top....
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 06-16-2012, 05:45 PM   #433
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Smile Abby gets Marmoleum
Today was the day for Abby to get her new Marmoleum installed. After cutting the sheet from the template, we rolled it up and placed the sheet through Abby's front window.
ID:	161168Click image for larger version
Then we carefully unrolled the sheet and did a little cleaning to make sure there wasn't any little specs of dirt or debris.
Then I troweled on the glue and rolled and rolled and rolled. Did a little clean up and here is how she looks.
ID:	161173Click image for larger version
ID:	161174Click image for larger version
Lance
Old 06-16-2012, 06:06 PM   #434
1981 31' Excella II
That is TOP job is ever I seen one. Great work.
Perry
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
