Old 05-20-2012, 10:25 PM   #365
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Leak test with the SealTech 430r
Soldiermedic was very gracious to lend me his SealTech 430r for a while. I figured I'd see how many leaks Abby had. As you may, or may not know, water leaks are the bane of the wooden sub-floor in an Airstream. I found a few leaks. Well, maybe more than a few, but definitely a manageable amount.
These first two pics show the main door hinge and the utility receptacle.
ID:	158859Click image for larger version
Looks like a new gasket is needed for the scare light.
This is forward of the main door where the old awning attachment bracket was screwed to the side of the trailer without any sealant.
A small leak under the trim at the rear of the trailer.
Another leak from the trim.
Leak at the water heater/rub rail trim.
So now it is time to fix all of those leaks.
Lance
Top is offline   Reply With Quote
Old 05-20-2012, 10:37 PM   #366
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Well, I guess it's now or never.
I've been looking for the time to replace the rotten floor in the front of Abby. You can't make time, only use it, so I decided I better use the time I have before the big summer trip to finish the fixing of the rotten floor and frame. I didn't really intend to replace the floor and fix the frame right now, it just sort of happened. After the leak test, I kept on walking around Abby, looking at the dinged and dented banana wraps, smelled the rotten wood and nasty insulation and looked at the calendar and decided it was time to just get it over with.
This afternoon I went to the shop and started with removing the front banana wraps and belly pan. Not surprisingly, the front frame looks much like the rear frame did.
ID:	158866Click image for larger version
The belly pan always has such interesting things inside.
Lance
Old 05-20-2012, 10:58 PM   #367
x
XXXX , XXXX
Hey Lance is image # 3 the main frame rail? If so is that the area around the entry steps or is it the area around the fresh water tank? The reason I ask is that I've seen damage to the main frame rail in both spots on several trailers so far and would like to know if it's atypical.
wasagachris is offline   Reply With Quote
Old 05-20-2012, 11:13 PM   #368
1966 26' Overlander
troy , Indiana
rotten flo woe's
looks like a nice project you have there and your floor is actualy better than mine at teh moment i am looking for someone to glean me they're knowledge. The bolts that hold the frame to the wall sill through the floor have some sort of square head on them and i dont know what they have underneath the frame. Can anyone tell me what tools i will need to get these off i ask partly due to the fact it doesnt feel like a hex head at teh bottom. could be wrong its happened before
hondasub is offline   Reply With Quote
Old 05-20-2012, 11:14 PM   #369
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Yes,Chris. It is the main frame rail just forward of the step out rigger. It is very near where the A frame is welded to the main frame rails.
Lance
Old 05-20-2012, 11:25 PM   #370
x
XXXX , XXXX
So I would suspect that the damage was caused from water penetration throught the A frame open front ends and collected where the A frame joins to the main frame rail.
I see similar damage around the entry steps again from water penetration through the slots in the outriggers for the step glides. I have also found that water gets in around the corner of the frame for the fresh water tank. The Zee angle that the water tank plywood sits on has a removeable front section and has small openings right on the corners.
Old 05-21-2012, 05:34 AM   #371
Baltimore , Maryland
Water goes down, not up...
Major issue #1. The steel in this era is incredibly rust prone. Money was saved on the steel alloy and it shows in every trailer of this era. They also skimped on the paint. Often it is almost non existent on the frames of this era.
Major issue #2. When the water flows down, it is directed into the belly by the wraps laying over the skin and not under as they should. Again, this was done to save labor.
These units were built when we as a Nation, full embraced the ideal of disposable everything. Longevity was not an objective. I happen to like 1970's trailers, I think they have very cool lines and the windows are awesome, but they were not made with the same pride as those of the previous eras. Quality control has always been an issue. Cost point has too.
Old 05-21-2012, 07:11 AM   #372
Mr & Mrs S's Avatar
Newton , Texas
Well...
Well Top, Looks like you'll be firing up the ole welding machine again.
Glad to see Abby getting all the attention.
Didnt realize that you needed to do the front flooring as well
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 05-21-2012, 08:23 AM   #373
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Jeeze! A few weeks before the Albuquerque Rally. You going? In Abby?
Old 05-21-2012, 08:49 PM   #374
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Lucky to have done this a few times.
Yes the welder will get a workout over the next few days. I've been putting this off for a long time now. I finally have some time and space to get it done. It will help me get it done knowing I have a trip planned in three weeks.
I do what I can to not dispose of things. I agree that it surely wasn't made to last forever, but I think I can get another 30 years out of her.
There are tons of places for the water to get in. When it can't get out or evaporate, it is even worse.
We are going on our summer trip. I plan to leave June 9th. We are going to NM, but not ABQ. I have a lot of work to get done.
Lance
Old 05-21-2012, 09:00 PM   #375
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
A morning's work
Well, after a few hours this morning I managed to get some work done.
ID:	158945Click image for larger version
ID:	158947Click image for larger version
I even had a lucky spider watching me.
Lance
Old 05-21-2012, 09:01 PM   #376
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Frank....I'm speechless -- I thought you hated us 70's trailer trash!
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 05-21-2012, 10:17 PM   #377
reinergirl's Avatar
Hollis , New Hampshire
Attachment 158949
Lucky spider? Whatcha drinking buddy cause spidey's aren't lucky
I heard you on the VAP (EVERYONE listen to the latest episode!) Awesome, just awesome! I was like OH MY GOODNESS .... IT's TOP.... and my family was like "Top who?" Geesh.... losers
Congrats buddy and best of luck in the business!
reinergirl is offline   Reply With Quote
Old 05-22-2012, 01:12 AM   #378
You are confusing me for someone else...
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
