Old 01-08-2013, 03:29 AM   #481
1972 31' Excella 500
Mount Vernon , Is For Lovers
Outer skin pigtail
Originally Posted by Colin H View Post
Yeah, anywhere on the main frame rails. Use a ground lug.
Colin
I would suggest a "pigtail" wire from the rear mounting plate to ground as an extra safety measure to prevent energized "skin" from any errant voltage.Keep up the great work you are a talented instructor and you are providing a wealth of information and OJT that we are very appreciative of.I will be following your lead approximately 2 years hence.
Sylver Slypr is offline   Reply With Quote
Old 02-27-2013, 10:21 AM   #482
1973 25' Tradewind
Beautiful , Oregon
Ronco Tanks
Lance,
Your tanks from Ronco are look like they are ABS or Fiberglass but when I called they told me theirs were Polyethylene.
Can you advice?
I really like your set up I want to generally copy it. I have to see if I can relocate or work around my attached levelers.
Anyway If you could let me know I sure would appreciate it.
Tony
Tony S is offline   Reply With Quote
Old 02-27-2013, 10:45 AM   #483
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Tony,
Yes, they are roto-molded poly.
I took the stabilizers off and use two small aluminum screw jacks on the rear.
Lance
Top is offline   Reply With Quote
Old 04-03-2013, 10:31 AM   #484
1973 25' Tradewind
Beautiful , Oregon
Hi Lance
Following your lead I picked up the 17H for my Black and Grey water tanks from Ronco. Rich treated me well and I recommend them to others. We are in the process of building frames pretty much like the ones you did. No sense in reinventing the wheel.
I was curious, you said you were going to wait awhile to enclose the tanks, have you done that yet and if so what did you come up with?
I also was wondering when you come from your grey tanks to the in front of black tank valve am I seeing it right that it is three inch? In the picture of your grey tank outlet it has the 1 1/2" reducer, so is that to carry water from both tanks. Anyway, read through your thread again and many thanks it is a bit of a guiding force in my attempt at bringing some more life to my 1973 TW.
Tony
Tony
Old 04-03-2013, 03:03 PM   #485
1973 25' Tradewind
Beautiful , Oregon
Hi Lance
Here is our version of your tank carrier design. We didn't hang it off the frame quite the same as you did my buddy decided to weld a "block" and drop it on the leg of the channel stringers.
Also at the outlet area we you some flat bar we had on hand double up. The pedigree is all yours.
Thanks for your example
Tony
ID:	182396   Click image for larger version
ID:	182398   Click image for larger version
Old 04-20-2014, 02:28 PM   #486
1964 24' Tradewind
Enumclaw , Washington
We just bought a 1964 TradeWind 24'. It was renovated by the previous owner and the sheet goods in the main part of the trailer are getting pretty tatty. I have a couple of big pieces of Marmoleum but since the new cabinets are already installed, I am very reluctant to disturb them. I am thinking about taking out the old sheet floor and installing 1/4" Baltic Birch sub floor. Were crossing our fingers that the frame is OK. Is there a good way to check without tearing everything up?
I'm attaching a photobucket link so you can get some idea.
Airstream Land Yacht Photos by wolffullmoon | Photobucket
This is our first trailer and we are very excited to get it out.
Put a new axle and jacks under it as well as wheels and tires. Safety stuff is more important than cosmetics.
wolffullmoon is offline   Reply With Quote
Old 04-21-2014, 08:04 AM   #487
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Crossing your fingers has never worked for me. Hopefully you have better "luck" with that than I have. The only way to know if the frame is sound is to remove the belly pan, all the nasty fiberglass insulation and rodent nests and look with your own eyes. You'll know what you have and won't need to cross your fingers.
Congratulations on the new to you trailer. Like having children, your life will be changed forever!
Lance
Old 06-24-2014, 12:50 PM   #488
1971 31' Sovereign
Lake Minnetonka , Minnesota
Great thread top, I'm working on the rear separation of a 1971 sovereign and this has been the most helpful thread i've found. I'm headed down to benning in august, the plan is to live out of the Airstream, original AC still works, for now......
Got a few questions for you, I need to add a grey tank, in the next frame opening up from the black tank, I have zero welding skills, know of an alternative bracing system for the new tank? Also i dont know how to plumb it in with everything, should i just join it to the existing black tank? if so what would be the most cost efficient and painless way of connecting the current grey water run off into the dual black tanks? currently the black water runs into the tailgate hatch and I would like to elbow it to a street side valve. Do I need to weld a hole like yours?
bakes is offline   Reply With Quote
Old 10-15-2016, 05:19 PM   #489
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Top, regarding your Marmoleum installation, if you wanted to lay Marmoleum all the way into the rear bath could you have done that with one continuous piece or would you have had to lay a separate piece in the bath area. Would the seam show and would it eventually spread apart due to temperature fluctuations despite being glued down?
Kelvin
Old 10-18-2016, 10:01 PM   #490
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Welding
Kelvin
Kelvin,
The Marmo was used in the front to mimic the finish of the rear half of the trailer. It was never a consideration to cover the rear half.
It can be done. If properly installed, you would only see the seam under the bed or in the closet. If you have marmot installed by a Pro, they can weld the two sheets together. The sheets are 2m wide.
Lance
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
