Old 05-28-2011, 09:19 AM   #295
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Originally Posted by Jim & Susan View Post
Mornin' Top. I've been reading thru your thread and remembering my trip down this road. You're doing a fabulous job, keep it up!
I think I have one of those cutting boards out in the garage someplace (and lots of other stuff, as well). We don't intend to use it. It's yours if you want it.
Thanks very much Jim. I would love to have the cutting board if you aren't using it!
Lance
Top is offline   Reply With Quote
Old 05-28-2011, 11:56 AM   #296
Mr & Mrs S's Avatar
Newton , Texas
Your bathroom components look really good. I think the painter done a great job!
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 05-28-2011, 04:47 PM   #297
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks JS, For what it cost, $579, it should look like new. I think they look pretty good. Unfortunately, under the new paint is old plastic. This stuff is a PITA to rivet back into place. I should be able to wash my hands in the sink and flush the toilet by tomorrow evening.
Lance
Old 05-28-2011, 06:05 PM   #298
x
XXXX , XXXX
Lance that will be much better than the other way around. It will certainly involve a lot less kneeling.
Seriously though they do look great and so does the A/C cover. Your cover is different than mine. It is one piece and mine is a two piece unit. I would suggest a screen set up like I did to keep the debris out. Mine was chock full of crap when I took off the original one.
wasagachris is offline   Reply With Quote
Old 05-29-2011, 09:03 PM   #299
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Tedious work
Thanks Chris. I plan on using some kind of screen over the fan. Just haven't figured out what exactly.
Today I got a fairly early start. Then I had to pick up my daughter from a sleep over and take her to Guitar Center to get some new strings for her guitar. I also made a trip to Lowe's for some more flexible hose from the city water inlet to the pex plumbing. There was too much interference with the routing of the hoses. The under sink cabinet would not fit properly. It took a bunch of sweating, cussing and grunting, but I did manage to get the whole bath surround installed and plumbed. The sink works!
I have most of the trim installed in the bath. I sealed the joints with Trempro 644 white silicone RTV. I then sealed the top of the trim piece with the same RTV after it was installed. I attempted to install the white insert that goes into the trim extrusion. I lubed it with some soapy water and pushed it in as far as I could. I could only get about two feet to go in before it stopped sliding. I jacked around with it for about an hour or so, pushing, pulling, cussing and grunting to no avail. Any suggestions would be appreciated. It isn't going to stop me from finishing this, but I'd eventually like to have the proper trim insert installed.
I know I thought I'd have the toilet installed, but I am missing one of the flange bolts. I should have checked to see that I had all the proper parts before leaving for Lowe's. It is one of those maintenance management "P"s I preach to Soldiers about.
P4T4
Problem
People
Parts
Plan
Tools
Time
Training
T
echnology
I should get a bunch of things done tomorrow.
Lance
Old 05-29-2011, 09:41 PM   #300
soldiermedic's Avatar
Florissant , USA
Awesome work....Can't wait to see her next weekend.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-29-2011, 10:09 PM   #301
x
XXXX , XXXX
Lance That looks fantastic. Better than a new A/S.
For the A/C I had a local window and door company make up a window screen, painted it silver and attached it to the shroud with stainless screws. That way it is easily removable for servicing and cleaning if needed.
A couple of suggestions for the trim. What if you lubed the extrusion instead of the trim? Also can you place the bottom of the trim in the extrusion and then flex the trim and use a hook tool to get the top of the trim to go into the extrusion?
You're almost done. I bet by next weekend Abby is ready for the road.
P.S. I painted my tambour doors with Krylon white spray paint that I got from Wally Mart. It worked great and looks like new. I know it's a little late now seeing that you've already installed yours but just an idea.
Old 05-29-2011, 10:37 PM   #302
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Major maintenance
Thanks Steve and Chris.
I lubed the trim and the insert. Just wasn't going to go in. It can wait. Thanks for the tip. I'll try some other ways like the hook slider.
I should be ready for the road by Wednesday. I'll take her out for a test drive and make sure everything is working and get the cob webs shook off, so to speak! We will be going on our first camping trip since January next weekend! We're going to the First Annual Central Texas AirForums Rally in San Marcos. Can't wait. It has been a long time and a LOT of work. When I look at a picture like this from January, I know that I have really done something. I have never worked so hard on any project before. Keep in mind I have been in aircraft maintenance for 22 years now and have taken aircraft and their sub systems down to the basics, rebuilt/repaired/reassembled them and gone for the post maintenance test flight. Rebuilding an Airstream is really challenging and rewarding! I couldn't have done what I have done in five months without this forum and the help of its wonderful members like you reading this right now.
Lance
Old 05-29-2011, 11:16 PM   #303
pbearsailor's Avatar
Port Hadlock , Washington
Lookin' very good, Top! Congrats on the second running water pic.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 05-30-2011, 07:12 AM   #304
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Steve! This evening there will be a flushing water pic!
Lance
Old 05-30-2011, 08:17 AM   #305
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Man!!! You just gotta LOVE them floors. Up against the fixtures that is really unique lookin'! Love it, man, love it!.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
He is your friend, your partner, your defender, your dog. You owe it to him to be worthy of such devotion.
bwoodtx is offline   Reply With Quote
Old 05-30-2011, 10:03 AM   #306
Florissant , USA
Top,
Will the trim I sent you with for the floor end up working?
Steve
Old 05-30-2011, 10:08 AM   #307
Tool Hoarder
West , California
Attachment 131057
Lookin good! Funny how long ago January feels. I still look at my inspection pics and trip on how far I have come. But I really try not to think about how far I have left to go, yikes!!
marzboy is offline   Reply With Quote
Old 05-30-2011, 10:52 AM   #308
Central , Mississippi
Hey Top-
I figured you would be grillin' today! I was firing up the wood fire pit and thought of ya...
ribs and brisket today...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
