Old 05-20-2011, 11:24 AM   #253
soldiermedic's Avatar
Florissant , USA
Time for the crew to come help after school it sounds like to me.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-20-2011, 03:54 PM   #254
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Just got back from the plumbing supply store. Here is what $570 of plumbing supplies look like. I'm using Viega Pure Flow fittings with Fostapex tubing.
ID:	130275   Click image for larger version
Lance
Top is offline   Reply With Quote
Old 05-20-2011, 04:14 PM   #255
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Hi Top,
It's always good to have a second pair of eyes, and I could also learn something from helping you with your plumbing. If you'd like a hand, let me know. It's just a short drive up there from Round Rock, and I do need to put some miles on my truck!
TX-16
Dave Park is offline   Reply With Quote
Old 05-20-2011, 04:25 PM   #256
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks for the offer Dave. I wouldn't mind some help. I'll send you a message. Maybe Steve could even get in on the action. He has also offered to help many times.
Lance
Old 05-20-2011, 06:00 PM   #257
x
XXXX , XXXX
Dang why are all you helpful Texans so far away. Or is it me that is too far away. Anyone want to travel a little bit to do some polishing.
wasagachris is offline   Reply With Quote
Old 05-20-2011, 06:25 PM   #258
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Dave.....does this mean you're feeling better? I've seen that you've been posting a lot more as of late...the A/S itch coming back?
Originally Posted by Dave Park View Post
Hi Top,
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 05-20-2011, 06:35 PM   #259
Dave Park's Avatar
2005 22' Safari
I'm very much feeling better and have been given a clean bill of health.
I've been easing back into 'life' over the last couple of months - it feels good, let me tell you!
TX-16
Old 05-20-2011, 07:33 PM   #260
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Pex is moving along at a quick pace. If it hadn't rained earlier I'd be nearly finished. I wish I'd have bought this stuff last Friday.
Lance
Old 05-20-2011, 07:56 PM   #261
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I'd like to travel a little bit but not to polish!
Lance
Old 05-20-2011, 08:08 PM   #262
Florissant , USA
Can't wait for the pressure test
Steve
Old 05-20-2011, 08:22 PM   #263
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Steve
Every initial PEX pressure test of mine looks like an indoor sprinkler system. It needs to be pushed all the way into the fitting, then pulled back on.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 05-22-2011, 06:04 PM   #264
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Drainage
Well, not a bad Sunday at all I guess. We had some friends over for a small BBQ. My good friend and fellow 1SG is leaving for Afghanistan next week. I hope he enjoys being in the stone age as much as I did when I was in Afghanistan.
I managed to finish the drain plumbing this evening. Working with ABS is not bad at all. When the glue dries I'll fill 'er up to the P trap and see if there are any leaks. Here are a few pics.
ID:	130434Click image for larger version
ID:	130436Click image for larger version
I wasn't planning to re plumb under the galley, but I have a small issue finding an adapter to connect the pex to the original (I think) water lines. Neither copper line is standard 1/2" copper water service pipe. I can fudge the one line with a sleeve. The other is no where near close. Probably best to yank it all out under the sink and install new stuff.
Lance
Old 05-22-2011, 06:22 PM   #265
Florissant , USA
Everything looks good. Hope everything is dry when you fill er up.
Old 05-22-2011, 06:54 PM   #266
x
XXXX , XXXX
Really looking good Lance. See what did you need a pro for, you did handle it just fine.
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 05:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 08:36 PM
