Old 05-15-2011, 05:27 PM   #239
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Appetizer. Home made ciabatta makes the best bruschetta.
Lance
Top is offline   Reply With Quote
Old 05-15-2011, 07:19 PM   #240
soldiermedic's Avatar
Florissant , USA
Ok, my marinated thighs don't compare to a whole bird rotisserie style, but I'm working with what I got here!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-19-2011, 10:36 AM   #241
Tool Hoarder
West , California
Let me guess you love food?
Oh where did you get your insulation? Cant find it anywhere!!! Why did you go with that insulation?
marzboy is offline   Reply With Quote
Old 05-19-2011, 12:15 PM   #242
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Insulation
Food is an art form around here! My wife is Italian, so we have a nice mix of Italian and American food.
I got the insulation from the local lumber yard. They had to order it from the wholesaler in Dallas. There was a minimum order of 22 sheets. It was a bit pricey at $24 per sheet, but I think it is worth it. I read a lot of threads on insulation here. I chose polyiso because it is what Frank uses at Frank's Trailer Works as well as Brett from Timeless Travel Trailers. It is relatively easy to install on flat surfaces, but takes some geometrical wizardry for curved sections. Attached is the product info sheet. I think the best thing about it is that it doesn't hold water.
Lance
Old 05-19-2011, 07:58 PM   #243
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Plumber! Can I get a plumber over here?
Well, let's see. Where was I? Oh right. Plumbing.
I have decided to install all new Pex plumbing with Viega fittings in Abby. No biggie right? I'm kinda getting crunched for time so I figured I'd hire out the plumbing job to have a professional job and save some time. I figured that I'd call a few plumbers and see where that would get me. Three of the four plumbers I called actually came out and looked at Abby's plumbing needs. The first was a very large plumbing company here in town. They took a day to show up and two days to call me back with a quote of "between $750 and $950". Plumber number two was actually a mobile RV repairman. He said he was pretty busy and asked if I could call him later. I never called him back. I don't think I should have to call more than once. Plumber number three showed up and looked around and said he had never heard of Viega fittings, but he would use compression fittings. He said he would give me a call later that evening. That was Monday afternoon. I haven't heard from him since. After all this I went to the plumbing supply place here in town to just but the tools and parts and do it my damn self! I was giving the list of things I thought I'd need to the guy at the counter. He gave me a few raised eyebrows and explained things to me. While I was there at the counter, plumber number four was listening in to my explanation of why I was doing it myself. He said he could help me. He gave me his card and said to give him a call if I needed anything. Even just an answer to a question I may have. He went on his way to fix a sewer line or something. So the guy behind the counter totaled up the supplies and tools that I thought I'd need and it came to about $450. I thought about it and decided to give plumber number four a call to come have a look. He came this afternoon and said it would be around $750. He also would guarantee his work as long as he was still alive. He said he'd be here tomorrow at 0900. I hope he can get it done in a day.
Tuesday I cleaned and reinstalled the belt line trim. That was a chore. I had been putting it off because I knew it was going to be a PITA. I used some 5/32nd closed end rivets from Fastenal. I'm not too impressed with their performance. I sealed the upper part of the trim with Sonolastic NP1. I used some regular 3/16th pop rivets where I needed extra grip length. It was a chore, but it's done now.
Before
ID:	130226Click image for larger version
After
ID:	130223Click image for larger version
ID:	130224Click image for larger version
Yesterday I went to SA to see the Muganga. While I was there I saw Soldiermedic. He gifted me some nice things he said I'd be likely to use. Thanks Steve!
Earlier this morning I went to the body shop where the plastic bath components are getting painted. I took the toilet over to him to color match. I also took the A/C shroud to be painted silver. I have a few pics of the pieces ready to paint. They should be ready on Monday.
ID:	130228Click image for larger version
ID:	130229Click image for larger version
ID:	130230Click image for larger version
Making headway. Tomorrow I'm going to work on the bumper storage hatch.
Lance
Old 05-19-2011, 10:11 PM   #244
Florissant , USA
Nice progress. Glad you are going to be able to use the stuff I gave you, and can't wait to see some of it in use.
Steve
Old 05-19-2011, 11:32 PM   #245
LawChick's Avatar
1992 29' Excella
1987 32' Excella
Morrilton , Arkansas
Images: 55
That floor is beautiful. Your thread helped us. We had only the ugly beginnings of separation, but decided to "nip it, nip it in the bud," to quote Barney Fife! LOL
Luckily everything was still securely attached to still solid frame. Whew.
You sure do good work! Thanks for letting us learn as we follow along.
Carol
2004 Dodge Ram 2500 Cummins HD
1987 Excella 32'
"Besides, I'm a gypsy at heart
and I like to travel around."
Reba McEntire
LawChick is offline   Reply With Quote
Old 05-19-2011, 11:53 PM   #246
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
I can't believe the price of the pex and fixtures you got... you should PM pbearsailer (Steve)... he did all his Pex himself with a crimper... I don't think he paid that much. Another thought is to rent the crimper for a couple of days? I have to admit that copper doesn't seem so expensive now! I cheaped out with cpvc about 8 years ago... still works fine.
Glad it's all finishing up soon!
Marc
Old 05-20-2011, 06:31 AM   #247
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Pex Plumbing
If price were no object, would copper be the best choice? I have used CPVC and copper in homes, and I always feel like I took a short-cut when using the CPVC, even though it has held up just as well as the copper.
Bauxter is offline   Reply With Quote
Old 05-20-2011, 06:38 AM   #248
Bauxter's Avatar
1973 31' Sovereign
Columbus , Ohio
Top, In the picture of your back bumper (post #243), it looks like there is a gap between the body and the bumper storage area cover. Did you find a solution to the water issue at the back bumper (where water flows back onto the plywood)?
Old 05-20-2011, 08:48 AM   #249
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks and Pex price
Marc
Thanks Marc! I think I'm in the "committed" stage now.
LawChick,
Thanks so much. I hope you have safe and enjoyable travels this summer.
Bauxter,
I'm not a plumber, so I think that my opinion on if copper is a better choice than pex isn't worth much. I know it takes a lot more labor hours to install copper than pex. Maybe a master plumber will be able to help.
My plan with the bumper storage compartment is to leave a 1/4" gap for water to run down the back of the trailer and into the storage compartment. When I put the rearhold down plate under the floor I filled the groove and attachment surfaces with 3M 560 polyurethane adhesive sealant. There should be no way that water can get between the rear hold down plate and the sub floor unless I failed to properly seal everything. I am modifying the floor of the bumper storage compartment with drainage holes from a wide 6" strip of perforated sheet aluminum. I'll post pics of it when I complete it in the next few days.
Lance
Old 05-20-2011, 11:33 AM   #250
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Angry Guess I'll do it myself
Well, plumber number four did not show up at 0900 as he said he would. He didn't call to say he would be late. Nothing. I waited until 0950 and gave him a ring. I got his voice mail. I politely told him don't bother with coming over to plumb my trailer. I'll do it myself. It is very frustrating. I have wasted a whole week on trying to have a "pro" do the plumbing. Always learning!
Lance
Old 05-20-2011, 12:07 PM   #251
Florissant , USA
Geez Louise.
I can be there in a couple hours. What do you think?
Steve
Old 05-20-2011, 12:15 PM   #252
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Bring $450 and meet me at the Ham and McCreight plumbing supply! Just kidding. It'll be alright.
Lance
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
