Old 04-19-2011, 09:12 PM   #197
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Red light on, BAD
Thanks guys. I was just reading a thread about that. Now I understand. I guess that when I was plugged in at the house the last time my extension cord modification was the cause. I have a new extension cord now.
Lance
Top is offline   Reply With Quote
Old 04-19-2011, 09:12 PM   #198
x
XXXX , XXXX
Lance here is the page from my service manual showing how the polarity light is wired and how to trouble shoot it.
Name:	Polarity wiring.jpg
wasagachris is offline   Reply With Quote
Old 04-19-2011, 09:14 PM   #199
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I should read my service manual a little more often I guess
Lance
Old 04-19-2011, 09:25 PM   #200
x
XXXX , XXXX
Maybe you also need to remodify that extension cord too.
Old 04-19-2011, 09:26 PM   #201
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Always learning...
Lance
Old 04-19-2011, 09:41 PM   #202
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Chris,
Thanks for the compliments. I'm thinking of having either some louvered slots or some machinery cloth for the bumper storage compartment to drain out of.
Question
Is there any reason that the little red light that comes on when shore power is applied would be wired between the Neutral and the ground? I know it used to work when I had her plugged in. Now it doesn't. I opened the cover and found it is wired like that. I pulled one lead off the N and shoved it up in the L and it came on like it used to.
Top,
That little red light is a polarity light & should only come on if your trailer is plugged into a socket that has the neutral (white) & the load (black) wires reversed. This system is an antiquated system that alerts you to a power source that was wired incorrectly.
If your trailer also had another issue in that the neutral was grounded somewhere in the trailer, you would have what is called the "hot skin" condition. This is very dangerous because if you step out of the trailer & have one hand touching the metal skin & one foot on the ground at the same time, you may get electrocuted. You need to make sure the ground & the neutral never come together in the trailer, anywhere. Also, make sure the entry box & lead cord are wired correctly with the black wire connected to the load side & the white wire connected to the neutral buss.
You should also disconnect the polarity light system, as this will cause problems if you plug into a GFCI protected socket. The GFCI system is a somewhat more sophisticated than the polarity light & will cause the GFCI to "pop" if the differential between any of the three wires (green, black or white) does not meet certain criteria.
As the polarity light is a 120 volt lamp that is wired between the neutral & the ground, it will only light up if the neutral is live. This of course is not a good thing. Although your trailer may be wired correctly, there are many campgrounds out there that have handymen that don't have a clue what they're doing & reverse the neutral & the load somewhere in their system.
Now, even if your trailer is wired correctly & you plug it into a campground that is wired correctly & it has GFCI outlet, the GFCI will pop because of the polarity lamp still in the system. Do youself a favor & take it out & make sure you test your complete trailer with a tester, then you & your family will be safe.
Colin
Colin H is offline   Reply With Quote
Old 04-19-2011, 10:03 PM   #203
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Colin. I was just reading a thread about the "hot skin" condition.
I will take your advice and remove the polarity light. I was all over the trailer this afternoon probing for stray voltage. I didn't find anything unusual. Just a light hooked up to the neutral! I'm kinda wondering about the bare ground wire that goes from the ground bus in the service box to the frame. Where is the best place to ground the box to the frame. It was at the rear hold down plate. I know that that isn't the best place. Just anywhere on the main frame rails?
Lance
Old 04-19-2011, 10:19 PM   #204
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yeah, anywhere on the main frame rails. Use a ground lug.
Colin
Old 04-22-2011, 07:18 PM   #205
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Good Friday
I hope y'all are enjoying your day. Today I took the shroud off of the air conditioner to give it a good cleaning. I hosed it down with water, blew it out with air, repeat about a dozen or so times. It is sparkling clean now and blowing nice cool air. I had some water leaking inside so I cleaned off the old sealant and applied C-10 Flo-Seal. I need another tube! It is really runny stuff. It was 93 degrees here today so it was getting a workout this afternoon. I don't have the insulation in the walls yet so that doesn't help any. Here are some pics of the AC.
ID:	127883Click image for larger version
I then started to replace the road side outer belly skin. It is all dented and corroded. The four or so hidden rivets were a pain to drill out. I'm using 6061 T6 .025"
ID:	127886Click image for larger version
I also took the water heater out of the box and placed it in the hole. I kept the stainless cover from the old water heater in hopes of using it again. Don't think I can make that work. I believe I'll re-skin the cover with some 2024 alclad. The white just isn't going to work for me.
Lance
Old 04-22-2011, 07:38 PM   #206
soldiermedic's Avatar
Florissant , USA
Attachment 127888
Until then...spray paint is your buddy. My 56 caravanner had a spray painted cover that was previously white.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-22-2011, 07:52 PM   #207
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
first I've heard of the polarity light actually causing a problem.
never popped a campground breaker. I've also never seen the light "on"...never tested it, either. maybe its not connected.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-22-2011, 09:23 PM   #208
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
What happened to the Caravaner? I don't remember you ever talking about a Caravaner.
It shouldn't take me too long to put some nice overlay on the door. The more I think of it though, I may just take the tank and control from the new one and put it in the old water heater shell. I'm not too fond of how the new unit's frame was made. It is really flimsy.
Lance
Old 04-22-2011, 11:28 PM   #209
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
It won't pop a normal breaker, it'll pop the GFCI.
Colin
Old 04-23-2011, 07:31 AM   #210
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah...I'm just thinking that if gfci hookups are common in campgrounds, I must have (statistically speaking) plugged into one at some point. I used to plug into one at my house and never had a problem.
Like I said..maybe the polarity light is disconnected.
We'll see when I pull the bathroom out and embark on my own rear floor-rot repair journey.
Air:291
Wbcci: 3752
'73 Safari 23'
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 06:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-04-2011 12:22 AM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 09:36 PM
