Old 04-16-2011, 11:33 PM   #183
Trex's Avatar
1981 20' International
Shasta Lake City , California
Nice floor, Trainer of Personnel!
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: http://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 04-17-2011, 04:41 AM   #184
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Nice floor!
Baseman is offline   Reply With Quote
Old 04-17-2011, 04:56 AM   #185
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Beautiful job. You should be able to float your AS. it will be so watertight. The next person to remove that floor will need dynamite. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 04-17-2011, 06:28 PM   #186
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I just read your thread for the first time. Impressive that you have done so much in a short amount of time. I have also done quite a bit of metal work on my project. Mine is somewhat delayed due to all the road trips my job has taken me in the last few years.
http://www.airforums.com/forums/f416...nte-26902.html
Old 04-17-2011, 07:04 PM   #187
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Thanks Rex, Baseman, Sal and Aerowood.
Aerowood,
I have read all of your thread. You are doing some great work. I have read most of your posts about rivets and sealants. I'd like to have used ProSeal between the rear hold down plate and the exterior skin, but I used 3M 560 polyurethane adhesive sealant. I didn't intend to but a "project" trailer. I was just unknowing at the time. That is why I'm "always learning"!
Lance
Top is offline   Reply With Quote
Old 04-19-2011, 01:13 PM   #188
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
No more Separation!
No more sag. No more rotten wood falling in my eyes. This is truly a solid floor! (well in the back half of the trailer at least!)
I used all stainless hardware. The elevator bolts, hex head bolts, washers, lock washers, and nuts. I completely covered the hardware in the C channel with 3M 560 adhesive sealant. I drilled three holes through the C channel for drainage. I filled them in with epoxy and re drilled the hole through the epoxy so they are waterproof. I used aluminum plate for the 3/8" bolts that go through the C channel into the main frame rails. I'm sure it will last for another 50 years or so. Here are some pics of the hardware.
ID:	127595Click image for larger version
ID:	127598Click image for larger version
ID:	127600Click image for larger version
Lance
Old 04-19-2011, 01:21 PM   #189
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Skin and hold down plate
Here are some pics of the skin under the rear hatch and the .06" stainless hold down plate from inside.
ID:	127603Click image for larger version
ID:	127605Click image for larger version
Lance
Old 04-19-2011, 02:49 PM   #190
soldiermedic's Avatar
Florissant , USA
Nice Job Lance...I'm looking forward to seeing you camp in her really soon.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-19-2011, 06:04 PM   #191
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Steve.
This afternoon I hooked up the electricity so I could run the A/C while working inside. It was very hot and humid here today. I also glued all the drain pipes for the gray and black tanks and did a little MOC (Maintenance Operational Check). Checked. Found OK! It was nice to see 75 gallons of water running out the drain pipe!
I'm brain storming on how to best attach the bumper compartment lid with out creating a dam that holds water on top of the bumper storage lid. I'm thinking of bolting an AL angle between the frame rails and leaving about 1/4" gap for water to drain down below. I'm not too concerned about keeping water out of the bumper storage compartment. I don't plan on putting anything in there that can't get wet.
Lance
Old 04-19-2011, 06:15 PM   #192
x
XXXX , XXXX
Lance I'm offically jealous now on two counts. One is that your weather is so hot that you need the A/C and the other is that you're so much farther ahead than me and will be camping soon.
Excellent work as usual. The floor looks fantastic.
I have been wondering about the bumper storage compartment as it is really part of the belly pan. If it fills up with water it may leak into the belly and get trapped. I did seal it abundantly with Vulkem and am thinking about drilling some drain holes into the section of the pan that makes up the compartment bottom. I want to do a test and see where the water lies once it gets in before drilling the holes.
wasagachris is offline   Reply With Quote
Old 04-19-2011, 06:53 PM   #193
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Question
Chris,
Thanks for the compliments. I'm thinking of having either some louvered slots or some machinery cloth for the bumper storage compartment to drain out of.
Question
Is there any reason that the little red light that comes on when shore power is applied would be wired between the Neutral and the ground? I know it used to work when I had her plugged in. Now it doesn't. I opened the cover and found it is wired like that. I pulled one lead off the N and shoved it up in the L and it came on like it used to.
Lance
Old 04-19-2011, 07:58 PM   #194
x
XXXX , XXXX
Lance what little red light are you talking about?
Old 04-19-2011, 08:02 PM   #195
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
he is talking about the polarity light on the left side of the trailer.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 04-19-2011, 08:04 PM   #196
x
XXXX , XXXX
I thought so but wasn't sure. It should never be on unless the polarity is reversed.
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Top 1970 -1973 Ambassador 254 01-01-2016 05:07 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 08:36 PM
