Old 05-03-2011, 06:13 PM   #221
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Smile Water heater, electrical plug and interior insulation
Well. A lot has happened in the world in these past few days. It has been a while since I have posted any progress. Since the last post I have installed the water heater completely. I also insulated most of the the interior walls. The insulation I am using is Dow Tuff-R 1" polyisocyanurate. It is the same as I used for under the floor. There is a nice slot in the stringers that the Tuff-R slid into. That gives about a 1/2" air space between the outer skin and the foil face of the Tuff-R. I have some Reflectix I'll use for the curved sections of the rear. I also used some Roxul in the areas around the wheel wells and a few areas that I couldn't access. Here are some pictures.
ID:	129040Click image for larger version
ID:	129044Click image for larger version
I also installed the Furrion 30A plug I ordered from VTS. I used the old cable. I put on a nice Cooper electrical plug on the original cord. Works great.
ID:	129042Click image for larger version
This was playing as I was finishing up.
YouTube - RATM -Killing in the name - official video
You'll find many Soldiers that LOVE this song. We bear the burdens of our political wranglings. We do it with pride!
Lance
Lance M is offline   Reply With Quote
Old 05-03-2011, 09:47 PM   #222
soldiermedic's Avatar
Florissant , USA
Ah Rage....great stuff to get you riled up before S%&T hits the fan.
Looking good Top, see you and Abby in a couple days.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-03-2011, 10:27 PM   #223
Trex's Avatar
1981 20' International
Shasta Lake City , California
Looks like it was a good day for the Navy Seals....looks like they got some good intel also.
"Sometimes you eat the bear, and sometimes, well, he eats you." -the Stranger-
Come and see me at: https://www.airforums.com/forums/f185...-71804-60.html
Trex "Airstream Nomad"
Trex is offline   Reply With Quote
Old 05-04-2011, 10:53 AM   #224
Baseman's Avatar
1974 25' Tradewind
Ponchatoula , Louisiana
Baseman is offline   Reply With Quote
Old 05-07-2011, 09:13 PM   #225
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Wink Cuss words and insulation installation
Thanks Baseman, Rex and Steve.
I have been continuing with the insulating. I finished the underfloor insulating. That wasn't much fun. Here is how it goes;
measure, crawl out from under the trailer, cut a chunk of insulation, crawl under trailer, trim, cut, cuss, screw it to the underside of the sub floor them repeat.
After that was done it was time to finish the interior insulating. It wasn't as hard as the underfloor insulating, just a tad more cutting. I can't getthe last section of insulating done until the city water inlet is installed. VTS to the rescue!
Soldiermedic dropped by the house on Friday. It was nice to have someone see my progress in person. Thanks for stopping by Steve!
I'm at home. Many are not. Happy Mother's Day to all the Moms!
YouTube - Five Finger Death Punch Far From Home
Lance
Old 05-08-2011, 09:50 AM   #226
Florissant , USA
Top, thanks for allowing me access to see your secret squirrel project (Code Named "Abby"). It was nice to have a break from all that driving, and gave me a chance to see everything you have done on a larger scale. Also major props to Mrs. Top for her mad skillz in the kitchen. Top, I un pasto meraviglioso avuto. Look forward to the next time.
Steve
Old 05-08-2011, 06:43 PM   #227
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Steve
Thanks Steve. That's funny (Mrs. Top)
Lance
Old 05-09-2011, 06:59 PM   #228
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Plastic bathroom component repairs
Today I worked on repairing and prepping the bathroom plastics for paint. They are in pretty good shape, but have a few cracks here and there.
ID:	129481Click image for larger version
ID:	129482Click image for larger version
I'm using 3M 4240 semi-rigid plastic repair kit to repair the cracks from behind.
ID:	129484Click image for larger version
The 3M product works very well but has a few shortcomings. The work time is VERY short. Like +/-15 seconds. Once you stop squeezing the goop out, the tip gets hard and you must replace it. If you squeeze too much goop out, it gets hard before you can level it out with the spatula. A fine balance is needed to make it go a long way. It is expensive too. One 300ml kit is $52. It comes with two mixing tips. A six pack of extra mixing tips is $15. The 3M squeezing gun was $48. There are decent instructions with the kit. What was helpful was the "how to" videos on youtube. I sanded, cleaned with adhesive cleaner, sprayed the adhesion promoter, waited 10 minutes for it to dry, then squirted the goop out and schmeared it smooth with a putty blade. In about 10 minutes it can be sanded. I sanded it smooth and applied another layer.
Here are pictures of the front side after repair.
ID:	129487Click image for larger version
And the back side
ID:	129488Click image for larger version
I'm happy with the results. Tomorrow I'm taking the bath components to the paint shop. Here they are all ready to go to the paint shop.
Lance
Old 05-14-2011, 08:28 AM   #229
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Smile Making progress
The last week has been pretty good as far as progress on Abby.
I got the plastic bath components off to the paint shop. The man says that it'll take about a week.
I got the insulation all finished in the belly. I still need to tape the seams.
ID:	129778Click image for larger version
I got the outer sections of the belly pan all fastened to the outriggers. The white splotch you see is a bird deposit. No, we don't have our anti gravity device operating here. It was deposited when I had the sheet laid out on the bench. Birds seem to love to poop on shiny aluminum.
I received the city water inlet from VTS on Wednesday. It came very fast as I just ordered it last Sunday. It was cheaper and faster to order it from VTS than ordering it, then driving to pick it up when it would arrive at Crestview RV in Georgetown 32 miles away. I prefer to deal with local suppliers if at all possible, but with gas at $4 per gallon, it is sometimes not the logical choice.
I finished all the interior wall insulating and re installed the interior walls. I had to replace one small strip of the interior wall under the rear hatch. The old piece was not salvageable. It had a bunch of corrosion and was also melted at one point from a plumbers torch. Some 2024 .032 worked great.
I think I'm about ready for plumbing. Here are some before and after shots.
ID:	129786Click image for larger version
ID:	129783Click image for larger version
ID:	129782Click image for larger version
ID:	129787Click image for larger version
Lance
Old 05-14-2011, 08:32 AM   #230
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
One small mis calculation
I forgot all about the heat duct when I was planning the inlets for the gray tanks. I guess I'll have to make an adjustment to the ducting. I might just go with insulated flexible ducting.
ID:	129788Click image for larger version
Lance
Old 05-14-2011, 08:41 AM   #231
x
XXXX , XXXX
Greta work lance. The floor looks fantastic. I have to admit when I first read about your plan for the floor I had some reservations but it is wonderful looking. The insulation job looks very similar to what I did.
It won't be long now and you'll be camping again.
I bet Abby smells a lot sweeter now with all that mess gone.
BTW when does Lorelei arrive in the lone star state?
wasagachris is offline   Reply With Quote
Old 05-14-2011, 12:29 PM   #232
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks Chris. I'm very happy with the way the floor turned out. We'll see if it stands the test of time.
Lorelei will have to remain in MN until I get Abby completely finished. Might make a trip up there this summer some time.
Lance
Old 05-14-2011, 01:07 PM   #233
x
XXXX , XXXX
Lance I meant to say great work not greta work. Some time my brain works faster than my two fingers can type.
Here's a link to a heating duct supplier for RV's. They have all kinds of different sizes of ducts and adapters to use.
DWIncorp.com Flexible Heat Duct
Old 05-14-2011, 04:32 PM   #234
Florissant , USA
Attachment 129788Attachment 129789
Always learning.
Old 05-14-2011, 04:43 PM   #235
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Heat, what heat!!!??? This is SOUTH Texas. You don't need no stinin' heat! Ruh Ro
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 05-14-2011, 05:30 PM   #236
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Always learning.
Well Bruce, I sure was glad we had the heater working when we were at Blanco in December. Also the heater came in handy when we were camping at Big Bend NP for New Years!
Thanks for the link to the ducting, Chris. I'll be able to adjust fire as necessary.
Lance
Old 05-14-2011, 05:33 PM   #237
Florissant , USA
Top, there are about 900 ways you could get by without a furnace. I'm sure you can make something work.
Old 05-15-2011, 04:11 PM   #238
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Slow progress today. Installed the inner wheel wells and made a support for the water heater. We're having some chicken here too.
ID:	129906   Click image for larger version
Lance
Old 05-15-2011, 04:27 PM   #239
Always learning
Lance M's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Appetizer. Home made ciabatta makes the best bruschetta.
Lance
Old 05-15-2011, 06:19 PM   #240
Florissant , USA
Ok, my marinated thighs don't compare to a whole bird rotisserie style, but I'm working with what I got here!
1972 ambassador, 29', rear end separation, floor repair
Abby gets all the attention Lance M 1970 -1973 Ambassador 269 09-02-2022 04:58 PM
Rear storage crack and separation of trim 2008 Classic 30' SilverBeast Exterior Storage Compartments & Access Doors 37 04-03-2011 11:22 PM
1976 Safari Rear end Separation??? mile2885 Repairing/Replacing Floor &/or Frame 4 01-25-2011 08:36 PM
