04-16-2011, 08:25 PM
#181
1975 Argosy 26
1963 24' Tradewind
Seattle
Whooo! That floor is beautiful!! So did you tint the epoxy or something to get in that nice warm orange color? It looks different then the underneath? Home Depot also sells the craft paper that builders put down to protect floors while they work on homes.. I think it's got some post it type sticky to keep it down.
Marc
04-16-2011, 08:51 PM
#182
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
3M
If you look back to posts from January, you'll se I used water based minwax stain before three coats of epoxy and three coats of Defthane polyurethane floor finish.
Lance
04-16-2011, 11:33 PM
#183
1981 20' International
Shasta Lake City
Nice floor, Trainer of Personnel!
04-17-2011, 04:41 AM
#184
1974 25' Tradewind
Ponchatoula
, Louisiana
Nice floor!
04-17-2011, 04:56 AM
#185
1981 27' Excella II
mays landing
, South Jersey
Beautiful job. You should be able to float your AS. it will be so watertight. The next person to remove that floor will need dynamite. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
04-17-2011, 06:28 PM
#186
1971 21' Globetrotter
Arvada
I just read your thread for the first time. Impressive that you have done so much in a short amount of time. I have also done quite a bit of metal work on my project. Mine is somewhat delayed due to all the road trips my job has taken me in the last few years.
http://www.airforums.com/forums/f416...nte-26902.html
04-17-2011, 07:04 PM
#187
Always learning
1972 29' Ambassador
Central
Thanks Rex, Baseman, Sal and Aerowood.
Aerowood,
I have read all of your thread. You are doing some great work. I have read most of your posts about rivets and sealants. I'd like to have used ProSeal between the rear hold down plate and the exterior skin, but I used 3M 560 polyurethane adhesive sealant. I didn't intend to but a "project" trailer. I was just unknowing at the time. That is why I'm "always learning"!
Lance
04-19-2011, 01:13 PM
#188
Always learning
1972 29' Ambassador
Central
No more Separation!
Lance
04-19-2011, 01:21 PM
#189
Always learning
1972 29' Ambassador
Central
Skin and hold down plate
Lance
04-19-2011, 02:49 PM
#190
Florissant
, USA
Nice Job Lance...I'm looking forward to seeing you camp in her really soon.
Steve
04-19-2011, 06:04 PM
#191
Always learning
1972 29' Ambassador
Central
Thanks Steve.
This afternoon I hooked up the electricity so I could run the A/C while working inside. It was very hot and humid here today. I also glued all the drain pipes for the gray and black tanks and did a little MOC (Maintenance Operational Check). Checked. Found OK! It was nice to see 75 gallons of water running out the drain pipe!
I'm brain storming on how to best attach the bumper compartment lid with out creating a dam that holds water on top of the bumper storage lid. I'm thinking of bolting an AL angle between the frame rails and leaving about 1/4" gap for water to drain down below. I'm not too concerned about keeping water out of the bumper storage compartment. I don't plan on putting anything in there that can't get wet.
Lance
04-19-2011, 06:15 PM
#192
x
XXXX
, XXXX
Lance I'm offically jealous now on two counts. One is that your weather is so hot that you need the A/C and the other is that you're so much farther ahead than me and will be camping soon.
Excellent work as usual. The floor looks fantastic.
I have been wondering about the bumper storage compartment as it is really part of the belly pan. If it fills up with water it may leak into the belly and get trapped. I did seal it abundantly with Vulkem and am thinking about drilling some drain holes into the section of the pan that makes up the compartment bottom. I want to do a test and see where the water lies once it gets in before drilling the holes.
04-19-2011, 06:53 PM
#193
Always learning
1972 29' Ambassador
Central
Question
Chris,
Thanks for the compliments. I'm thinking of having either some louvered slots or some machinery cloth for the bumper storage compartment to drain out of.
Question
Is there any reason that the little red light that comes on when shore power is applied would be wired between the Neutral and the ground? I know it used to work when I had her plugged in. Now it doesn't. I opened the cover and found it is wired like that. I pulled one lead off the N and shoved it up in the L and it came on like it used to.
Lance
04-19-2011, 07:58 PM
#194
x
XXXX
, XXXX
Lance what little red light are you talking about?
04-19-2011, 08:02 PM
#195
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
he is talking about the polarity light on the left side of the trailer.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
04-19-2011, 08:04 PM
#196
x
XXXX
, XXXX
I thought so but wasn't sure. It should never be on unless the polarity is reversed.
04-19-2011, 08:12 PM
#197
Always learning
1972 29' Ambassador
Central
Red light on, BAD
Thanks guys. I was just reading a thread about that. Now I understand. I guess that when I was plugged in at the house the last time my extension cord modification was the cause. I have a new extension cord now.
Lance
#198
x
XXXX
, XXXX
Lance here is the page from my service manual showing how the polarity light is wired and how to trouble shoot it.
04-19-2011, 08:14 PM
#199
Always learning
1972 29' Ambassador
Central
I should read my service manual a little more often I guess
Lance
04-19-2011, 08:25 PM
#200
x
XXXX
, XXXX
Maybe you also need to remodify that extension cord too.
