Old 06-14-2015, 04:09 PM   #1
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
A Frame frame extension/rebuild
It has been nearly ten years, time flys, since I saw a thread on this. Now it is my turn to work in this arena and I need some up to date, reliable, advice and info. Attached photos are of the original A frame and hitch. At 31 inches it is to short for me to make reasonable turns without dinging the front corners of the Airstream. Also no room for a weight distribution hitch to be attached. So, lets hear the procedure and words of wisdom. Experience goes a long way.
Name:	1953 Liner A frame hitch.jpg
ID:	240640   Click image for larger version
Name:	1953 Liner A frame length 31 1:2 inch.jpg
Name:	1953 Liner A frame width.jpg
Old 06-14-2015, 07:50 PM   #2
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
A clean tongue
I can offer dimensions of a similarly sized trailer that trails well.
Dimensions...
1968 Globe Trotter is 20' 11 long. Dry, weighs <3000 pounds, 400# Tongue Weight. The A-Frame is 36 From body to the ball and 32 wide at body-face of trailer cabin.
WD/Sway...
With five years of use, I've been very pleased with the Reese mini 350 WD System. It's a sensible, harmonious contraption. Mine is adjusted to tip 280# onto the front TV wheels, and 140# to the Trailer wheels. That's about 5% beyond its spec. It is quick and clean to set-up. Weighs 35 pounds including Bars, Shank & Head. The brake-shoe composition friction pads atop the A-Frame provide good anti-sway, and operate silently.
With regards to Lightweight trailers, what is pictured is very satisfactory in terms of easy hitching, anti-sway, weight distribution, minimal added tongue weight, quiet operation, excellent ground clearance, backs up and turns sharply without consequence. It has a relatively clean appearance.
I switched to a single 40# propane bottle. It's base is mounted flush to the depth of the A-Frame, rather than on top. It is situated closer to the body to reduce TW. It does not interfere with WD, and reduces tongue clutter.
I don't know what level of historical protocol you require, or If you're thinking of updating to a newer Marvel coupler, or rebuilding what you have, or a total changing of the A-Frame to trailer frame, or extending the coupler 6?? If your coupler is good or rebuildable, maybe check out a few hitch systems for something compatible and preserve the original if that matters.
Anyway, those are the 1968 A-Frame dimensions for reference...
I'm guessing that you'll be towing at times, with a period correct TV.
ID:	240687   Click image for larger version
ID:	240689   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 06-14-2015, 09:03 PM   #3
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Nice work there
Nice! I need to know the effects of extending the a frame length about eight inches. And then, how to do it correctly.
Gaucho - New Frame / Extension Whizzo Cabinets, Counter Tops & Furnishings 0 01-24-2010 02:30 PM
Gaucho extension-any success stories?? Creampuff Cabinets, Counter Tops & Furnishings 29 10-14-2004 02:16 PM
extension cord rated for 20 amps? Martha Electrical - Systems, Generators, Batteries & Solar 15 02-28-2003 03:00 PM
What is the gray 7 3/4" long extension Kistler Our Community 11 12-10-2002 08:40 AM
