Old 04-18-2015, 07:06 PM   #1
1997 30' Excella
Corpus Christi , Texas
'97 Excella 30' leak hunting and ripping out carpeting
Name:	ImageUploadedByAirstream Forums1429405358.279212.jpg
ID:	236574Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405374.381499.jpg
ID:	236575Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405391.949758.jpg
ID:	236576Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405405.818350.jpg
ID:	236577Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405421.517606.jpg
ID:	236578Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405439.441206.jpg
ID:	236579Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405454.956674.jpg
ID:	236580Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405473.141661.jpg
ID:	236581Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405489.010779.jpg
ID:	236582Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405510.113177.jpg
ID:	236583Click image for larger version
Name:	ImageUploadedByAirstream Forums1429405544.067954.jpg
Knudsvig is offline   Reply With Quote
Old 04-18-2015, 07:08 PM   #2
1997 30' Excella
Name:	ImageUploadedByAirstream Forums1429405632.577240.jpg
ID:	236585ordered 50' of gasket from out of doors mart along with adhesive, parrbond and ad seal. I will win this battle.
Old 04-18-2015, 07:49 PM   #3
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
I know the first thing I did when I bought my '99 was to rip out all of the carpet in the storage areas, water pump housing etc. That helps me keep an eye on it, at least in some areas. The PO did put down cork laminate so I can't check that, but I try to keep up with the caulking. Good luck with your repairs!
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 04-18-2015, 07:52 PM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Check your windows by the front door, mine was leaking and running to the door.
Silverflames is offline   Reply With Quote
Old 04-19-2015, 06:57 AM   #5
1981 31' Excella II
New Market , Alabama
It looks pretty darn good to me. Look for loose rivets around the door frame and also a bad gasket or bent door. Also look for loose rivets on either side of the door. Leakers many times have a black residue around them where the rivets is moving around making black dust. You can usually hook your fingernail under them. Leaks don't always appear above where they come out on the floor. Window gaskets on fixed windows can leak as well as the seams in the aluminum frames. On windows that open, look for water puddling at the bottom. Replace gaskets if water is found. Don't cover anymore of the floor than you have to so you can inspect for leaks. If you use carpet, don't glue or nail it down unless you have to.
Perry
Old 04-20-2015, 09:28 AM   #6
1997 30' Excella
Thanks for the great advice. We have no plans to cover the floor anytime soon.
Took out all curtains too they are smoke stained and stunk! Not sure if they will go back in. Kind of like it without.
Door gasket is falling off and does not go all the way around.
Old 04-20-2015, 09:54 AM   #7
1981 31' Excella II
Your welcome. I would put some bleach on the molded area to kill all the stuff that eats the wood.
Perry
Old 04-21-2015, 12:18 AM   #8
1997 30' Excella
Will do!
Old 04-21-2015, 05:34 AM   #9
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
overall a good looking 18 year old floor. I would replace the toilet seal
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is online now   Reply With Quote
Old 04-21-2015, 06:37 AM   #10
1981 31' Excella II
Check the rear of the trailer very carefully. Remove that trim on the back and caulk that seem really well.
Perry
Old 04-21-2015, 01:46 PM   #11
1997 30' Excella
toilet seal
Should we go ahead and replace it now? Or wait until we are ready to do the floor?
Old 04-21-2015, 03:31 PM   #12
Airstream Driver
1997 30' Excella
Images: 51
Does it smell? Will you use the toilet?
If no then wait til you have to pull the toilet for the new floor
I have seen toilets being installed with a new floor that raised the toilet too high for a proper seal. I have used 2 seals before to remedy that situation.
1996 Airstream B190
AIR #13
Old 04-21-2015, 03:47 PM   #13
1997 30' Excella
No and yes. The trailer has a faint stale smoke/storage smell but not at all toilet stinky
Old 04-26-2015, 10:03 PM   #14
MtnCamper07's Avatar
1993 30' Excella
Salida , Colorado
I see the stains from your photos... were you ever able to identify where the water was coming from? Although the plywood looks stained, it does not appear to be rotten. My excella is a 93 and after sitting all of last year, I too will need to go poking around and check for leaks.
NB
MtnCamper07 is offline   Reply With Quote
Ripping a furnace out - help please! AussieGirl LP Gas, Piping, Tanks & Regulators 4 10-17-2014 12:15 PM
Ripping out carpet & putting in what? StreamRollin Repairing/Replacing Floor &/or Frame 34 08-31-2011 12:28 PM
Bird ripping out sound deadening material. DaveFL General Motorhome Topics 4 05-25-2010 12:20 AM
Ripping out interior 68 sovereign what to do with all the goodies. Viesel General Interior Topics 5 06-15-2008 11:16 AM
Out with the carpeting? missysanford Floor Finishes 4 06-01-2008 04:19 PM
