Old 05-25-2019, 11:18 AM   #1
blickcd's Avatar
Milford , Ohio
79 forward section of frame rail question.
I have nearly all of the belly skin off my trailer from the hitch back to the axles. My reason for doing this is I was pretty sure some outriggers had rusted and broken so I wanted to get in for inspection / repairs, and put a fresh coat of paint on the frame.
I'll digress and say that two years ago I did the same at the back to repair some rotted floor, ended up repairing all outriggers, and was glad I got in there when I did.
Back to the forward frame... While the rear frame rails are just an open C channel and easy to wire brush and paint, the forward ones have a reinforcing piece of flat steel, with a row of maybe 1.5" holes all the way down. This piece is welded to the top and bottom of the C channel perhaps every foot, making it a box tube in a sense.
Wire brushing and painting the exterior of the frame will be easy, but what have people done to get the inside cleaned and preserved? Blast out the loose dirt and rust with compressed air and then spray in POR 15?
Thanks in advance.
Christopher
Its a camper, therefore it leaks.
blickcd is offline   Reply With Quote
Old 05-25-2019, 12:47 PM   #2
1986 31' Sovereign
Miami , Florida
I would do the exterior and then simply fog the interior of the tube with Corrosion X or Fluid Film.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 05-25-2019, 01:50 PM   #3
blickcd's Avatar
Milford , Ohio
Thanks for the reply. I have never heard of either product, but am sure I can research them easily enough.
Christopher
Forward Curtain Rail Captnsteve Airstream Classifieds 0 11-26-2018 07:52 AM
ISO: small section of 2” rub rail for 1979 Argosy RachBets Clearcoat, Exterior Paint & Trim 0 07-06-2018 04:57 PM
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Floor/frame separation fix - section or all at once? GlobeTrottin Repairing/Replacing Floor &/or Frame 11 05-12-2011 07:21 PM
Cross Section of Walls to frame? big-boss Repairing/Replacing Floor &/or Frame 1 08-11-2010 10:19 AM
