Old 04-06-2015, 08:06 AM   #1
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
'74 Overlander shell off today.....I hope. Question on rivets.
Is it necessary to remove these rivets?
2Rhinos is offline   Reply With Quote
Old 04-06-2015, 08:17 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yes, these go through the "hold down plate" or "shear plate" which connects the front of the body to the front crossmember. These were omitted on all Airstream's built after 1980 (as far as I can tell) which has caused all sorts of front end separation issues on longer newer model trailers.
Colin
Colin H is offline   Reply With Quote
Old 04-06-2015, 08:23 AM   #3
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Is it necessary to remove A/C & windows?
Don't really want to remove them at this time. Unless there is a compelling reason.
Old 04-06-2015, 08:27 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Depends on how you are doing the lift. If you are jackin it from below, thenthere is no need to remove windows and AC. If you are hoisting from above, then the windows don't need to be removed, but you might need to take out the interior AC ceiling assembly so that the beam you lift against doesn't damage it.
good luck!
Old 04-06-2015, 08:39 AM   #5
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
I've done over a hundred "body off" restorations, so the "compelling" reason is that the body won't come off the chassis if you don't...............big enough reason?
Colin
Old 04-06-2015, 08:47 AM   #6
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
good luck!
Did I miss something? The question was about the double row of rivets on the front panel, not windows.
Colin
Old 04-06-2015, 08:50 AM   #7
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Yep. .
Colin
I was asking about not removing the a/c & windows
Old 04-06-2015, 09:07 AM   #8
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Duuh, I didn't read the title on that post. If you're lifting through the roof vents, just remove the cover & fan if there is one on the front & rear vents. The AC is in the middle, so you can leave that there. The windows can stay in place. Lifting from below is far too much work in my opinion.
Colin
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Off to bring home a new baby (I hope) meredith Our Community 16 07-13-2011 09:11 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
