'73 TW Wet Bath Floor issues
I looked at a 73 Tradewind with a wet bath. As soon as I walked in i felt the floor flex substantially (was worked I'd crack the material) so I assumed the floor underneath was seriously compromised. I went outside and checked for separation by standing up/down on the rear end (I'm 270 lbs so this was a good test). While I'm not an expert on this test, I didn't detect any give in the shell it was moving with the rear frame with maybe a very slight give.
The question is: the wet bath was relatively small - does it make the floor repair/replacement any easier or will I end up having to remove the rear cabinets/slide out gaucho in addition to the wetbath to make the repairs.
