Old 08-15-2019, 07:59 PM   #15
1973 31' Sovereign
Tiffin , Iowa
The Eastwood Encapsulator plus will here tomorrow, so thatís a done deal lol. They have this aersol spray that has a two foot long nozzle that you can slide up inside the frame to coat the inside I got that as well. I ended up contacting a local shop for sandblasting he said $200 to blast, $100-150 to paint. Iím a big DIY guy, but sometimes you choose your battles. Lol. Itíll be a least two weeks before I make another step with my schedule. I love the input. Thanks!
Phil17g is offline   Reply With Quote
Old 08-20-2019, 03:11 PM   #16
1973 31' Sovereign
Tiffin , Iowa
Frame repairs under way
Frame repair on the Airstream. Airstream wanted $32 a piece for each out rigger and I needed probably 14 making them well over $400. I opted to have a local shop take 14 gauge steel and bend it into a C channel then took my plasma cutter and cut the half circle on the end and squared up the other side with my chop saw. This cost me $100. I had Sam grind the slag off the frame while I fabricated the pieces and welded them on after squaring them up and using a long piece square stock to make sure they aligned up. Also Sam is my wife.. 🤩
ID:	350008   Click image for larger version
ID:	350010   Click image for larger version
Old 08-20-2019, 07:18 PM   #17
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello Phil17g: I was born and raised in Iowa. Lived there over 40 years. A great state in my view.
You don't mess around. The body of this old Sovereign does indeed look to be in good shape. You will make the frame good again and replace the rotted subfloor. Now you have "good bones" to build your "new" old Airstream.
A renovation of this magnitude will be spendy with all the stuff you will likely need. I'd budget $15k anyway. But still much cheaper than a new one.
I have a 75 Overlander that I'm in the latter stages of renovating. Nothing spectacular, but a good solid trailer the whole family can use. You might like taking a look at my "project thread" linked below. I didn't do a shell off, but I did do quite a bit of frame repairs. Check out Airstream Forums "Knowledge Base" toward the bottom of the Forums page. Click on Sovereign, then your model year. You will likely learn lots about your trailer there. You might even like to start a project thread so the rest of us can easily follow along your whole project. I think it is better that spreading out in the individual maintenance topics.
Here is my Overlander on it's maiden voyage last month after the renovation.
David
Name:	1907 Campsite Awning-800x600.JPG
ID:	350037   Click image for larger version
Name:	1907 Curb-800x600.JPG
Name:	1907 Curtains Gaucho-800x600.JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 08-20-2019, 08:22 PM   #18
1973 31' Sovereign
Tiffin , Iowa
Hey dbj216,
We don’t enjoy Iowa, for the most part! That’s a nice looking Airstream you have there. I will definitely check out your project and move my thread to the Sovereign thread you suggested. I’m super new to any forum, so the input is welcomed. Thanks!
Old 08-20-2019, 08:35 PM   #19
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
Nice work on the out riggers, I did/am doing the same thing with mine.
Ian
Iansk is offline   Reply With Quote
Old 08-21-2019, 06:57 PM   #20
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
You're most welcome Phil17g: Start a project thread and I'll follow along. We were all new at Airstream Forums at one time. There are lots of helpful folks on these Forums that help new members where they can.
I'm planning on helping a friend with his 76 Sovereign twin bed rear bath this winter. It has rear end separation like many of them do. We are not planning a body off project. But I imagine we will be doing some frame repairs. I hope it isn't buckled.
When you get your Sovereign done, you can load up and take off in any direction your hearts desire.
David
WBCCI #8607
VAC Region 11
Old 09-03-2019, 02:51 AM   #21
1973 Argosy 26
Ojai , California
POR15 paint for the frame
I have a 1973 Argosy and the frame had some rust which I sanded down I have painted the original part my frame with POR15. And the back part that has been replaced, I am using another type of paint because the back half of the frame is new.
My question. I have read on the internet some not so great feedback about POR15. I have read in the AirForums thread people using POR15 and liking their results. Iím curious, for the folks who have used POR15 on their frame, what is your experience? Did it hold back the rust?
Thanks in advance for share your insights.
Kimya W is offline   Reply With Quote
Old 09-03-2019, 06:11 AM   #22
1966 22' Safari
Fredericksburg , Texas
I have no issues with the Por. Itís only been a couple of years but no signs of failure. As with any paint product, prep is the key. Also, Por is UV sensitive without the Por topcoat. Not so sure there arenít other metal paints that do as good a job as the Por at a a lot less cost. Good luck
Bubba L is offline   Reply With Quote
sovereign
1978 Sovereign Frame off wcronin4 1974 - 1979 Sovereign 300 09-10-2019 05:32 AM
78 Sovereign frame off wcronin4 Repairing/Replacing Floor &/or Frame 13 01-14-2019 07:06 PM
Frame off vrs. Frame on RedRdgRnr Repairing/Replacing Floor &/or Frame 19 05-15-2018 07:31 PM
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Frame off or not off... till Repairing/Replacing Floor &/or Frame 16 11-19-2003 05:20 AM
