Old 11-01-2013, 05:02 PM   #57
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
check the strainer at the tip of the faucet. That's usually the place where the sediment from the heater collects. Bettcha' a dollar.
Zep
Old 11-02-2013, 06:40 PM   #58
Tomball , Texas
Zep
I have low pressure even at the pressure release valve on the water heater...
TxBxSx is offline   Reply With Quote
Old 11-02-2013, 07:28 PM   #59
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Sounds like the pressure regulator or pressure relief valve at the fresh water intake.
Do you keep the intake covered when not in use. If not, you may have mud dauber problems.
I would pick up a fitting that will screw into the drain plug opening (1/2" NPT) with a hose connection on the other end. Then connect a garden hose, pressurize the system and see if you have good pressure. If so, I would remove the old hardware (Pressure reg and relief valve) and replace with a section of pipe. Then use an external regulator.
Old 11-03-2013, 03:58 PM   #60
Tomball , Texas
All plumbing in the trailer is brand new, and I replaced the fresh water hook up with this one which has a built in pressure regulator.
Vintage Trailer Supply, Inc. Mobile
The cold water side runs flawlessly, which is why I am thinking that the problem is the water heater. Heater has straight 1/2" fittings going in and coming out. I'll report back when I find out what pressure checks out to be before the water heater.
Where 2 buy 83 Sov window rock guard nustreamer Rock Guards, Segment & Window Protectors 2 07-16-2011 01:21 AM
airstream sov 1975 trailer eBay Watch Airstreams on eBay 0 05-16-2011 03:10 PM
airstream sov 1975 trailer eBay Watch Airstreams on eBay 1 05-13-2011 09:12 PM
airstream sov 1975 trailer eBay Watch Airstreams on eBay 0 05-03-2011 10:20 PM
04 Armada and 69 Sov or 75 TW Breadbug Tow Vehicles 2 01-24-2011 07:18 AM
