Old 05-29-2012, 08:42 AM   #1
1972 25' Tradewind
fort lauderdale , Florida
'72 Tradewind frame question
I purchased my 72 gutted and the PO had already replaced 2 main pieces of the frame running out to the bumper. Apparently rusted from the rear bath. The belly pan was also partially eaten away as you can see in the pics.
My question is, did the PO neglect to add back any rear outriggers? I have not found any pics on the forum of a 72 bare frame for reference. Any pics, dimensions, drawings and advice would be appreciated.
p.s. i've added 2 pics of the PO welds. They look ok but the 2x2 sq tube he has for support from c-channel to c-channel doesn't look like enough support.
ID:	159591   Click image for larger version
ID:	159593   Click image for larger version
ehodg66 is offline   Reply With Quote
Old 05-29-2012, 10:58 AM   #2
1981 31' Excella II
New Market , Alabama
Yes there should be some outriggers to support the shell. I would say there are two to three missing on each side.
Perry
Old 05-29-2012, 12:12 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
On my 68 there are no outriggers past the last main frame crossmember. Yours look OK.
The floor is the only support in the curves in the rear.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-29-2012, 01:10 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Looks OK. I would have welded a plate across the lap joint in the channel, but thatís just me over-engineering things.
The wet bath wonít cause as big a load as a full one.
If you havenít already, search the treads on water intrusion through the joint at the bumper box cover and body into the floor.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 05-29-2012, 01:24 PM   #5
1981 31' Excella II
I would consider putting a plate across the welded area to add more strength to the welded area. This would be a plate that would be welded across the center section going from top to bottom. The PO should have made an angled cut where the old beam meets the new beam. It will fail first at the weld and rust first there as well. My 81 center bath Excella II has outriggers in the last 4 feet of floor. This may be a rear bedroom addition to the floor that they did not think was necessary with the rear bath where most of the floor is covered with bathroom fixtures. It may also be something that changed over time.
Perry
Old 05-29-2012, 01:53 PM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have a 1968 Ambassador 28'. From the rear axel to the back I have 3 out rig supports on either side. You might be missing some.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 05-29-2012, 02:19 PM   #7
Tom Nugler's Avatar
1972 25' Tradewind
Here's copy of the chassis from my service manual. Might help a bit.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Old 05-29-2012, 04:24 PM   #8
1972 25' Tradewind
Thank you everyone for your input. I think I will take Toms advice and weld plates over the lap joints. Also, from the frame PDF supplied by Tom, it looks like I have all my outriggers but I need an added brace across the back directly under the shell. I'm sure i'll have more questions when I get the rest of my floor up.
Thanks again everyone!
Quick window question... daved20319 Windows & Screens 2 01-17-2012 04:44 PM
Can I just spray the frame with undercoating? robwok Repairing/Replacing Floor &/or Frame 5 12-01-2011 10:25 AM
Interior and Frame question LAarchitect General Interior Topics 2 11-06-2011 09:47 AM
Shell Off Question Evets Repairing/Replacing Floor &/or Frame 8 10-29-2011 07:36 AM
Between new floor and frame? surfpod Repairing/Replacing Floor &/or Frame 11 07-01-2011 06:21 AM
