Old 05-26-2016, 12:16 PM   #1
1962 22' Safari
Corpus Christi , Texas
66 safari shell off help
Alright boys and girls we need some help.
After a long hiatus because of illness we are back at it.
Interior panels are off, bottom exterior rivets out.
When we started to lift the shell off today we ran into trouble.
Our initial thought was that the C channel would stay with the frame and we would have the shell. But somewhere we are missing something. Some of the ribs seem to be attached to the c channel and other not. The one that are we can't really determine how.
Sooooo any thought or ideas on how to get this thing off. I should say that the back, which is basically rotted out and will be getting new frame work is lifting easy.
RevandDoc is offline   Reply With Quote
Old 05-26-2016, 01:54 PM   #2
Images: 59
Check for some hidden rivets that are behind the shell at the corners. You may need to slip a putty knife between the outside body sheet and the belly skin to break them loose.
Old 05-26-2016, 11:02 PM   #3
dcole's Avatar
1964 22' Safari
Portland , Oregon
I ran into this same issue today. I finally got my shell off! I found a single buck rivet that was under the skin and attaching the belly pan to a rib. I was able to drill it out of the rib from the inside. I used a center punch and drilled out the bucked material. I found a metal putty knife really handy on the inside also to break loose all the black tar-like stuff. Also, watch out for those hidden elevator bolts. I found the ones where the wheel well meets the wall especially hard to reach.
-good luck
dcole is offline   Reply With Quote
Shell off - How do I secure the shell once it's off? gronlampa Repairing/Replacing Floor &/or Frame 8 10-30-2015 12:22 PM
Shell on? Shell off? painterfam Repairing/Replacing Floor &/or Frame 11 05-30-2015 03:44 PM
Shell on shell off? Newbie Dustycowgirl Repairing/Replacing Floor &/or Frame 28 03-12-2015 12:12 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
