Old 03-19-2010, 08:31 AM   #71
JFerguson's Avatar
1964 26' Overlander
Gloucester , Virginia
clecoes
Well I am sold, now to find a bucker!!!! Unclog your ears gutter brains, I said bucker.
JFerguson is offline   Reply With Quote
Old 03-19-2010, 09:30 AM   #72
My wife was my bucking partner. She's great at it, and really enjoys it too.
Old 03-22-2010, 09:28 AM   #73
JFerguson's Avatar
1964 26' Overlander
Well I've got most of the windows working now. PO had riveted and screwed them closed. They aren't road ready but at least they will open. It looks like some kind of lynch-pin is missing where the regulator bar connects to the window frame rail. Without it the window can be lifted open by hand or by the pressure of air moving over the camper. All of the screens are missing, I think you can fabricate those...but I don't know I never tried. Some of the windows are missing the crank handles. They are shaped like a handle on a fishing reel. If anybody knows a good source of supply on them I need a few. Summer's in South Carolina are about as sticky and unpleasant as anyplace, and worse than most so I am glad I can get her opened up and aired out.
I finally finished removing the interior aluminum panels around the base and tossed all the old fiberglass insulation. The wiring still looks serviceable to me so I might try to keep it.
I see a number of rusty bolts with some kind of square nut going through the C-channel and the sub-floor. A friend is going to lend me his dremel tool and cutting wheels tomorrow. He also has a couple of cans of POR-15 he is going to give me free, never opened. I will probably take them by Lowe's and ask them to put them in the shaker for a few minutes. Those of you who remember 'Monster Garage' are singing FREEBIE, ZERO, ZILCH, NADA...
Old 03-22-2010, 12:55 PM   #74
JFerguson's Avatar
1964 26' Overlander
For those of you doing similar things I find the most effective tools so far is:
Electric Drill (plug in kind)
#30 bit
Pliers (my Leatherman tool is usually most convenient)
Awl
Hammer
Metal Putty knife
Vice-Grips
Safety Glasses
3M dust mask (the kind with the exhale valve)
Old 03-24-2010, 03:30 PM   #75
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Sawsall
Don't forget a sawsall,A grinder(for rust on the frame,and I invested in a 5hp compressor for an airdrill and air riveter.The grinder has been the best purchase so far
#30 bit
Awl
Hammer
Metal Putty knife
Vice-Grips
Safety Glasses
bwaysteve is offline   Reply With Quote
Old 03-24-2010, 03:58 PM   #76
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
This thread should give you a lot of info about your windows." 1964 mystery Hehr side Windows-Need Operators"
Kevin
kevinb is offline   Reply With Quote
Old 03-24-2010, 05:13 PM   #77
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
pics
Post some pics!!
Old 03-26-2010, 07:45 AM   #78
JFerguson's Avatar
1964 26' Overlander
I will have to take some photo's this weekend. Last weekend by the time I had made some progress and was ready to take pictures it was dark. I literally worked right up to dusk. Julie and the kids brought out KFC for a picnic but we ate it under starlight.
Old 03-26-2010, 07:46 AM   #79
JFerguson's Avatar
1964 26' Overlander
Kevin how do you get to that link? Looks like just what I need.
Old 03-26-2010, 06:02 PM   #80
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
I'm too computer retarded too know how to add a link, but click on kevinb then statistics, then find all posts by kevinb, scroll down and you'll see it. The thread was started by member ts8501, so you can find it through him also. Easy to work on hard to find parts.
kevin
Old 03-26-2010, 06:20 PM   #81
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
kevin
Glad to oblige. Here's the link.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 03-27-2010, 06:35 PM   #82
JFerguson's Avatar
1964 26' Overlander
Day 3 Pics
First those of you interested in our windows here you go.
ID:	98923   Click image for larger version
ID:	98925   Click image for larger version
ID:	98927   Click image for larger version
Old 03-27-2010, 06:42 PM   #83
JFerguson's Avatar
1964 26' Overlander
Day 3 Floor removal
Even though we've owned this Airstream for a few weeks this is only the third day I have actually worked on it. So it gives us a realistic estimate of time spent on work. Today I focused on on removing bolts and screws from the C-channel and taking out rotted plywood and nasty insulation. Mouse deposits were plenty, yuck.
Beginning Day 3 Forward: End Day 3 Forward:
ID:	98929   Click image for larger version
Old 03-27-2010, 06:47 PM   #84
JFerguson's Avatar
1964 26' Overlander
Beginning Day3 Aft: End Day3 Aft:
ID:	98931   Click image for larger version
It could have been worse.......... Robbie R. Off Topic Forum 15 12-10-2009 10:16 AM
THEFT - Worse Case clancy_boy Off Topic Forum 30 01-30-2007 10:59 AM
crapola. Tail repair worse than I thought eubank Repairing/Replacing Floor &/or Frame 7 03-25-2006 02:41 PM
If you think it is bad, it is probably worse j54mark General Repair Forum 5 09-27-2003 05:54 PM
Fleas and worse cjholloway The Pet Forum 4 08-09-2003 05:39 PM
