Old 06-08-2006, 01:41 PM   #1
Profile:  2007 25' Safari FB SE
valencia , California
1977 rear bath sag?
Are all 1977 rear bath models in danger of sagging?
Goin camping is offline   Reply With Quote
Old 06-08-2006, 02:15 PM   #2
klevan's Avatar
Profile:  Albuquerque , New Mexico
There are two separate issues often called sagging.
"Tail Droop" occurs in the 31' rear bath Airstreams built in the 70s
"Frame Separation." While most common in the longer, rear bath trailers,
all '77s are susceptible. I have found frame separation in 25' and 27' Airstreams.
There is a huge amount of information on these forums on both conditions, how to recognize them, causality, and cure.
In fact my response to your question will probably generate a deafening hue and cry. Be brave.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 06-08-2006, 03:35 PM   #3
If your reponse brings out the knowledge and opinions of others I will be gratefull.
How do you spot frame seperation?
Remember all I am a total newbie so please don't assume I know anything. Cause I don't.
Old 06-08-2006, 03:59 PM   #4
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
try this
hi- try standing on your rear bumper- it should NOT flex downward independent of the shell. Also use the "search" function here- there is tons of experience and info among members. -tim
tphan is offline   Reply With Quote
Old 06-08-2006, 06:42 PM   #5
klevan's Avatar
To spot frame separation, do what Tphan has suggested. Stand on one end of the rear bumper and bounce gently. If the seam between the belly band and the bumper opens and closes as you bounce, you have frame separation. Go to the other side of the trailer and bounce on the other end of the bumper.
Tail droop is caused when the frame members behind the axles bend downward on one or both sides. This causes the "tail" of the Airstream, both frame and body, to droop causing a characteristic buckle in the aluminum panels behind the wheel wells. There are pictures in various places on these forums. Search "tail droop."
Ken Levan
Old 06-08-2006, 07:29 PM   #6
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
How does one remedy tail drop if it occurs?
wacnstac is offline   Reply With Quote
Old 06-08-2006, 08:39 PM   #7
JimGolden's Avatar
Profile:  1977 31' Excella 500
Wacnstac,
The best way to fix this is with a new frame. Use a 6" deep section, with 1/4" thick flanges and a 3/16" thick (minimum) web and your problems are gone forever.
However, most people don't want to go to that extreme. There are doublers available from the factory (I believe) that can be welded or bolted to the frame to reinforce it.
- Jim
JimGolden is offline   Reply With Quote
Old 06-08-2006, 08:59 PM   #8
Images: 41
I'll just put some extra jacks near the back of my frame when I'm using the tanks
Pingbacks are On
1970 rear bath restoration GTracer Sinks, Showers & Toilets 22 04-24-2007 07:45 PM
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 05:09 PM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
SEO by vBSEO 3.1.0
