Old 02-08-2006, 04:39 PM   #1
Profile:  acton
Unhappy 63 tradewind floor replacement
Ive seen mentioned here on some threads about removing the body from the floor frame, is that necessary on the 63 to replace the floor??? If so I think Im going to be sick. I know on the earlier models some people have removed the body and rolled the frame out etc. Im just wondering if anyone has done this on a 63 tradewind and if so what worked for them.
Thanks in advance.
Mitch
durans54 is offline   Reply With Quote
Old 02-08-2006, 04:48 PM   #2
Wardinbb's Avatar
Profile:  1964 24' Tradewind
Big Bear Lake , California
Depends...
Hey Mitch,
...on how much floor you're going to replace. If it's the whole thing, then I think you could still get away without removing the shell by installing a 2' to 4' increment at a time. But I don't think you can expect to remove all the floor at once and just let the shell sit on the frame. So to what extent is the floor to be replaced?
Ed
Wardinbb is offline   Reply With Quote
Old 02-08-2006, 05:32 PM   #3
Profile:  acton
Thanks Ed for your reply,
From what I can tell its the rear 1/4 and front 1/4. What do you think, can I get away with doing this without removing the shell???
Thanks again
Mitch
Old 02-08-2006, 06:22 PM   #4
Profile:  1958 26' Overlander
Tijeras , New Mexico
I am one who thinks and did replace my entire floor without removing the shell - sorta - had the whole floor removed and lifted it a bit to slide the new floor in - did this because I did not have a place to lift/store the shell.....
If you do a search for 58 overlander restoration, you will see what I did - by the way, most years the floor installation is pretty much the same, so you should be able to find lots of pros/cons of on/off shell floor replacement.
Ken J.
1958 Overlander
Ken J is online now   Reply With Quote
Old 02-08-2006, 06:53 PM   #5
Wardinbb's Avatar
Thanks again
Mitch
Sure, why not? Are you sure its that much area? I redid 2' of the rear and about 18in. x 4ft at the entry. When you say 1/4, that's close to 6ft by the width. Get your ice pick out and start pookin'. Hopefully it will be smaller than you think. Regardless, you'll at least have to remove most of everything to get to your work area. Here's what you're gonna get when you get to it.
Ed
Name:	Entry 1of2r.jpg
ID:	18300  Click image for larger version
Name:	Entry 2of2r.jpg
Name:	Rear 1of2r.jpg
ID:	18302  Click image for larger version
Name:	Rear 2of2r.jpg
Old 02-08-2006, 06:57 PM   #6
Profile:  acton
I will start poking around like you said, maybe its not as bad as I think and I hope!
I will post what I find.
Thanks again
Old 02-10-2006, 03:07 PM   #7
Profile:  1973 31' Sovereign
Portland , Oregon
I am also one that believes you can replace the floor without taking off the whole body. I replaced the entire floor in my 1973 31' unit without lifting the body off the frame. There are indeed lots of pointers here in the forums to all sorts of techniques that people have used to replace part or all of their floors. I personally do not see any compeling reason to lift your shell off if you are just in need of doing a partial replacement.
Malcolm
malconium is offline   Reply With Quote
Old 02-10-2006, 03:47 PM   #8
Profile:  , Minnesota
Images: 55
Mitch,
Malcolm is correct. The main reason people (like myself) do a shell-off floor replacement is that we need to do other work at the same time, such as adding a greywater tank or doing major frame repair.
Non-supporting deadbeat non-member.
Old 02-10-2006, 07:28 PM   #9
Profile:  acton
Red face
well this makes me feel better. Ive been doing some poking around and see that I will have to replace the area at the entrance and forward along the edge towards the front on both sides, I will do this fall I think, dont want to get into it now.
Thanks for your replies
Pingbacks are On
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
'67 Tradewind: Where is my Univolt ??? Mike Rhodes Electrical - Systems, Generators, Batteries & Solar 5 07-21-2002 06:03 PM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
