Old 04-07-2014, 05:00 PM   #1
JCPOTTERF's Avatar
1963 28' Ambassador
Danielsville , Georgia
'63 Ambassador body lift
Made my first of two gantries yesterday quite a task by my self . At least getting it stood up. the interior is gutted below windows . Not much of the floor is left. Hopefully I will lift it off this weekend. Working 50 to 60 hours a week leaves little time for it, but i'm getting there. If I get the pictures to cooperate Ill use this thread to post more pics and progress.
Thanks for your help everyone
JCPotterf
63 ambassador International
JCPOTTERF is offline   Reply With Quote
Old 04-07-2014, 06:53 PM   #2
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Yes, please keep us posted on your progress....IMHO the 63 Ambassador is the best!
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 04-07-2014, 07:02 PM   #3
65CV's Avatar
Western , Massachusetts
Good luck! 50-60 hours PLUS work on an Airstream? Impressive.
Just double checking to save you headaches:
- you've heard warnings about tying down the shell so it doesn't lift off?
- you've seen Frank's writeup on making floor patterns before destroying it?
65CV is offline   Reply With Quote
Old 04-07-2014, 07:37 PM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Am looking forward to your progress!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 04-07-2014, 07:47 PM   #5
On adventure with H&G
MattB's Avatar
2012 30' Flying Cloud
1966 28' Ambassador
Lansing , Kansas
Hats off! Anxious to see how it goes. I like the gantry design.
MattB is offline   Reply With Quote
Old 04-10-2014, 07:25 PM   #6
JCPOTTERF's Avatar
1963 28' Ambassador
Second gantry up and in position. chain hoists up and boards in place to lift now i'm ready to start cutting rivet's. The front and rear of the floor is just rotted away so I will be making mine with out a good pattern but that's a ways down the road.
https://24.media.tumblr.com/8728093a...v10io1_250.jpg
Old 04-11-2014, 07:03 PM   #7
JCPOTTERF's Avatar
1963 28' Ambassador
lift off
Got it lifted off today, there's a few hidden rivets but i found them. I took a bunch of measurements of the floor then started pulling up what was left of the floor. The elevator bolts are kinda hidden in places. I used a few different ways to remove them . Including chiseling around them ,grinding them and then a hole saw method that works well too.
here's some pics.
Old 04-11-2014, 07:15 PM   #8
JCPOTTERF's Avatar
1963 28' Ambassador
floor bolts
If you place the hole saw just rite it just cuts the plywood and the plug can be pried out. Then when the floor is removed finish removing the bolts. heres a couple more pics
Old 04-11-2014, 07:19 PM   #9
1966 17' Caravel
I used the hole then bend them till they break method after the saws all and chisel method failed!
Cliff
Old 04-12-2014, 09:31 AM   #10
MattB's Avatar
1966 28' Ambassador
Lansing , Kansas
I am a big subscriber to the saws all method as well between each sheet and the top of the frame. Another option if you have a grinder is to put on a cutting wheel and cut them off from underneath, then just lift the plywood sheets off from the top. At least you aren't doing it in snow. Have fun!
Old 04-16-2014, 05:00 PM   #11
JCPOTTERF's Avatar
1963 28' Ambassador
Some questions
What do you replace cross channels with? The 55 inch by 4 inch channel with oval holes for air duct and plumbing. Can that still be found new ?
I need most of the 20 or so out riggers replaced and 5 cross channels !
I also need to splice in 6 feet of the rear frame . Thinking i will key splice it then box it in at the splice
The bumper could be saved if i can't find one reasonable.
Old 04-16-2014, 06:06 PM   #12
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Originally Posted by JCPOTTERF View Post
Some questions
I have these sections made to my spec at the local Steel Mill. This isn't very expensive. Have them done in .125" so your repairs will end up much stronger than original. The oval holes are not necessary. Depending on your fab skills, you can cut outriggers out of crossmember stock. Make sure you weld them on all joining surfaces when you reassemble.
Its unlikely that you'll find an original replacement bumper, so repair the original one.
Good luck,
Colin
Colin H is offline   Reply With Quote
Old 05-18-2014, 07:09 AM   #13
JCPOTTERF's Avatar
1963 28' Ambassador
63 ambassador body lift
Well Iv'e started splicing in my frame on the rear 6 ft. 300.00 for steel that includes enough for all new out riggers and a bunch of cross members. Here's some pictures.
I will reuse my bumper after I do some metal work on it
Old 05-18-2014, 04:41 PM   #14
1966 17' Caravel
Awesome improvise adapt overcome you have repaired with out going in the hole which is great and it is looking good!
Cliff
Body lift question JCPOTTERF Repairing/Replacing Floor &/or Frame 43 03-21-2015 11:01 AM
new body lift off method...easier sawdawg1 Repairing/Replacing Floor &/or Frame 7 04-11-2014 07:27 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 01:25 PM
Body Lift?? Morning Dew Axles 2 04-18-2004 05:53 PM
