Old 12-23-2005, 03:07 PM   #15
1962 24' Tradewind
greensboro , North Carolina
Thanks guys, 88 inchs it is then, next question.......
When attaching the channel to the floor(plywood) i want the channel to hang off 1/4 of an inch? Thanks in advance, you guys have been a great help as always.
Steve
scoxx30 is offline   Reply With Quote
Old 12-23-2005, 09:00 PM   #16
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Steve
Yup. You need a bit of room to wrap the belly skin. If the channel and the floor are exactly lined up, then the belly won't fit right.
Uwe
www.area63productions.com
Old 12-23-2005, 09:18 PM   #17
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Uwe,
I thought that the belly wrap went inside the outer skin. If the floor is outside the channel, then it will have a slight bend to the inside of the trailer at the floor.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 12-23-2005, 09:31 PM   #18
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by wkerfoot
Uwe,
Bill
Huh?
The floor needs to be slightly smaller than the perimeter of the channel. Not much, just enough to allow the belly to wrap down without creasing on the edge of the plywood below the channel.
Uwe
Old 12-23-2005, 10:00 PM   #19
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Huh?
Uwe,
I misunderstood, I thought the floor was slightly larger than the channel not smaller.
Bill
Old 12-23-2005, 10:12 PM   #20
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Hey Bill, you will be doing the same thing to the 2-door soon, right?
Uwe
Old 12-23-2005, 10:42 PM   #21
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Uwe,
Yes, hopefully we can install the first two pieces from the front in about three weeks.
Bill
Old 12-24-2005, 06:21 AM   #22
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Not sure of trailer widths ...
Originally Posted by Ken J
Fred: The question I was asking of you was not so much engineering data, but body dimensions. I know there was a change in 69 and 95 - were there any body changes between 58/59 and 1962? If not, then the floor width should be the 88 inches... Ken
Hi Ken: I'm not really sure. Very little of the sales literature lists body width, and that data certainly does not appear on an annual basis where a change could easily be spotted. The used trailer guides mention a "8 wide" Airstream in the late 1950s, but I think they grossly rounded up from the old 7' width and don't mean 96 inches wide. So, not having any clear understanding myself of annual actual trailer widths, I'll refrain from posting any data that might end up being incorrect. Instead, I'll say I don't know and leave it at that.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 12-24-2005, 06:36 AM   #23
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
My thoughts on this...
I do know that my 63 is narrower than my 71 was. I also know that after the 70's there was a change to a wide body. And, Bambis are again narrow.I believe Argosy Minuets had a narrower body/floor also.
We should collect owners data and make a sticky post in the floor forum.
Uwe
Old 12-24-2005, 09:19 AM   #24
1962 24' Tradewind
thats a good idea Uwe.
Old 12-24-2005, 10:02 AM   #25
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I'll start...
1963 Overlander - 88in plywood width, appr. 1/4in channel overhang on each side.
Plywood thickness on my trailer was 5/8in
Uwe
Old 12-24-2005, 12:43 PM   #26
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
58 overlander is the same as Uwe's
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 12-24-2005, 12:48 PM   #27
Images: 59
. . . . . and 59 Tradewind.
markdoane is online now   Reply With Quote
Old 01-02-2006, 09:47 PM   #28
used to have rivets
1953 25' Cruiser
1967 24' Tradewind
Sacramento , California
envy
Markdoane,
I soooo want my trailer to look like that picture of yours in 2 parts.
I have a 52 Crusier that I JUST FINISHED drilling the last rivet around the bottom.I have already removed the inside panels.
Anything hidden you can tell me about? I haven't started putting any preasure on it to seperate the 2 parts yet.
Thanks, Bruce
TooMuchTin is offline   Reply With Quote
'73 Tradewind for sale in Tampa Sneakinup 1970-79 Tradewind 1 09-20-2002 10:02 AM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Generator for a Tradewind uwe Generators & Solar Power 6 08-02-2002 08:51 AM
'67 Tradewind owners manual BentEar 1959-69 Tradewind 1 07-21-2002 05:15 PM
