Old 02-25-2005, 10:16 AM   #1
Thumbs up 57 overlander tail sag
any help with information concerning 2inch tail sag in a single axel 57 overlander? we are considering buy this trailer, it has a sag and seller states he was advised it could be fixed by bolting angle iron to frame and keep extra weight from rear. any help?
louvalake is offline   Reply With Quote
Old 02-25-2005, 11:02 AM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Could be one or both main frame rails which run from the front to the rear are rusted through, if so the floor is holding the thing together. You would need to look at the frame with the belly pan off aft the axel. If it is missing rivets in the outer or inner shell panels or there are "replaced" rivets or screws it may be breaking rivets from over flexing. Look at the rivets on the roof which can get alot of stress with a bad rearend.
Stand on the rear bumper and see if it moves different than the shell, ie floor separation. If you are going to park it somewhere and not travel with it then you can just put jacks under it. If you plan to travel with it be very careful unless you have lots of time and money to make it road worthy. If the frame is cracked the trailer will tear itself apart. Of course most all things can be fitted with time and/or money.
Over59 is offline   Reply With Quote
Old 02-25-2005, 11:58 AM   #3
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
I agree with everything Over 59 said above - and would add that I don't think the steel plate would be a good fix on this trailer - that fix was suggested for the 70's trailers that had rear end sag. I think the most likely cause is floor rot (we hope at least) - if the frame is good, then fixing the floor will solve the problem.
Another question - does it have a spare tire hanging on the back - that caused a lot of rear end sag on the 50's trailers.
I echo the advice you got in that if you do get if fixed - keep as much weight off the rear as you can.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 02-25-2005, 07:34 PM   #4
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I would side with floor rot as well after having done a shell off floor replacement. Look that the coach in my avitar. If you notice the side look a little bowed out. Its from rotten floor deck. When looking under the coach there was noticable sag from axle back. Once the floor was replace the structural integrity came back and it pulled the tail up and that bulged side went away.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
First shower in my 1975 Overlander !!! pjtaia Our Community 14 07-05-2015 12:46 PM
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
2-door Overlander InsideOut 1960 - 1964 Overlander 0 08-30-2002 08:14 AM
